For those with KN drop in filter....
did you feel any difference in throttle response. i'm not lookin for hp gains, just for better response. how has the drop in filter been so far and did u take out the 2nd filter or not and has that helped or hurt???
thanks in advance
thanks in advance
Just to add to that, I dyno tested my stock air filter with 10k miles on it and it dyno'd the same as it did when I had 3k miles on it.
I'd say just follow the manufactures suggested mileage replacement, unless you drive alot in harsh dusty conditions.
Super Moderator
At sea level, it won't do a thing.
However, at altitude, especially where I am at above 7,000 feet one can notice a difference, but there are none of these spectactular power gains or other garbage. Only advantage I can see is if you have a really restrictice OEM filter at my elevation, then the K&N might be an alternative
Depending on each specific engine and its design/tuning, there could be a slight power gain (if it’s slightly intake restricted) or loss somewhere in the RPM range by increasing air intake flow. No one can tell weather or not there is a gain somewhere unless there has been some testing (real world track testing or on a dyno).
It has been proven that not all air filters that increase air flow necessarily are less efficient. It has also been proven that the fit/design and media of the filter itself also has a big effect on its filtering efficiency. I have seen several analyses showing K&N filters to filter just as good as paper OEM filters, in several applications. Each application needs to have an UOA comparison to show how well it filters before anyone can make any claims. You can not just say that any filter does not filter well just because it performed poorly any one application.
I feel that if the filter does not compromise filtration in has the benefit of lasting the life of the vehicle, and can compliment a cat-back exhaust. Lets see some facts!
Super Moderator
When I in stalled the K&N several years ago, I could tell something was different in terms of the acceleration, but it really wan't enough to write home about.
We have about 25% less oxygen up here...thinner air.
If one wants power up here, they might as well use no air filter (which is exactly what I do despite the risks...because I was wasting so much gas with an air filter).
Not using an air filter WILL cause excessive engine ware. Your oil filter will go into bypass shortly and will not be filtering the oil at all. God knows what your intake system will look like and the effects. You will end up spending a lot more money in repairs then gas savings, if you keep the vehicle.
Koz
Here's a fact for you.
No matter what drop-in filter you put in the IS350 it's not going to make any more power. Unless you do some kind of scientific controlled test, you can rest assured the stock filter is your cleanest bet. Heck we still haven't figured out if removing the secondary carbon filter in the intake box lid frees up any power.
Koz
Tech Info Resource
For $40 you have a 91% filter. Stock is over 98%. Depends on your priorities. Also, oiled filters and MAFs are rarely good friends in the long haul. One over-oiling incident will completely negate the potential savings from the K&N.
I have run stock, K&N, and straight velocity stacks on a wide range of machines over the years so I am not speculating, just sharing my experience.
