High idle after throttle body cleaning.
Super Moderator
Your ECM needs time to compensate. I have done some spraying in my intake several times, and I always remember such isssues afterwards.
Alright I hate to be a pain in the a$$ but the car is running a high idle again. I'll wait another week or so but before I do I want to give a little more info. on the symptoms. I am NOT getting a CEL at all. It's pretty cold here in NY (about 25 deg.) but after a 5 minute idle and a 20 minute drive the car is still not even hitting the 1st line on the temp. guage! It's like the car is NOT coming out of the cold start-up mode. After my drive the car idles at around 1100 - 1200. In drive it idles at around 800. The other night I was driving for around 40 minutes and it never hit normal operating temp on the guage. It was only about 1/4 up the guage instead of halfway. I only cleaned the throttle body and now I'm getting this.
How I cleaned the TB:
I sprayed carb and choke cleaner on the throttle plate when it was closed and used a rag and tooth brush for stubborn areas. Then, I held the plate open with my finger and cleaned the TB walls (about 1" - 2" deep) with a rag soaked with carb cleaner. BTW... what is the little metal rod hanging down from the top of the TB when you open the throttle plate? If my memory serves me I remember this being dirty from the residue left behind when I was cleaning the TB. I realized that I had forgot to wipe it when I finished. Please help... or should I just wait another week or so.
I did re-set the ECU. Negative battery terminal was disconnected for about 1 hr. while I was cleaning the TB and doing other stuff. I did open the TB plate manually but I have read that this is only bad for the drive-by-wire systems which does not apply to 98-00. I have a 2000 GS400. I read through a search on these forums that by pressing on the gas pedal it will NOT open the flap for the 98-00 GS400's so you must manually open the TB plate.
I opened mine manually & it only idles high till it warmed up. you're saying the temp gauge never reaches operating temperature. The same thing happens all the time on my Ford Ranger. I'm not sure about the thermostat design on the GS, but on my truck....the spring gets weak and every 3-6 months or so The thermostat stays open, and the truck never gets to operating temperature...I guess its better than it not opening & overheating. I have no idea why it would decide to crap out now, but it seems like your thermostat isnt letting the car heat up.
You're not idling with the heat on high on anything that would rob the engine of heat are you?
After 1 week the high idle is still there!!! Also, I just filled up my tank on Wed. and and the needle is between the 3/4 and the half with only 58 miles tacked on??? WTF. Guys... did I ruin something on my TB? Let me know of any other "should not do's" when cleaning the TB. Please help! I'm desperate!!! The car is currently running OK though.
OK - The latest... I decided to retrace my steps and re-clean the TB. I am a D**K! I saw some Craftsman Professional Carb & Choke cleaner in my garage and used that on my TB last week. I thought it would probably clean TB also. Stupidly I did not read the directions that indicates DO NOT USE ON FUEL INJECTED VEHICLES. Now, I didn't spray it into the TB but still; what could have I damaged. This cleaner also indicates that it will NOT harm catalytic and O2 sensors. I cleaned the TB today with appropriate TB cleaner and re-set the ECU. It seem to be running great and has a normal idle but only when the temp. guage reaches the midway point. Even if it's a little under the midway point the idle in park is at 1100 rpm's. Is this normal? Also, what if any could I have damaged by using the carb & choke cleaner? Thanks.
