Intake Manifold
That's true of any aftermarket intake manifold. As said there are tradeoffs. It's up top where this manifold will shine. This is a stepping stone to making more HP and getting rid of the restrictive stock intake manifold.
I personally feel that the 1/2/3uz isn't even on the same planet with the 2jz in terms of performance right now. Isn't time we change that??
Eric
Eric
Lexus could have programmed the butterflies to open at any RPM and throttle. That they do not below 4400rpm suggests that more power is made with the longer runners below that rpm. I believe that power will be hurt below probably 5000rpm with the plenum design you have built.
Now, on a 2uz without vvti and without the butterflies in the intake AND with longer runners than the 1 and 3uz... you may pick up power above say 4000rpm compared to the stock 2uz intake.
Regardless, nice to see parts being built. Let us know how it performs once in use.
Again, this is just a stepping stone to more HP production. Items like VVt-I aftermarket camshafts, twin turbo kits, stroker kits, etc are all supporting characters in making the power. While the intake pictured above is a marvel of engineering, it's still not suited to make the power levels we're after.
I understand what you are saying about shorter runners affecting HP/TQ however it's sometimes it's a case of you have to give to get. Even if the V8 N/A with no other mods sacrifies a bit of low end, I believe that it'll more than make up for it on the top end. During accelleration onto a freeway onramp, most of the RPM's will be in the upper regions anyways. That's where a manifold like this really shines.
Personally though I an very impressed with the Toyota V8's. I believe that they need to be developed and made to deliver the goods much like the 2jz. I'm all about the performance of the 1/2/3uz. 800+rwhp kind of performance.
Thanks man!
Eric
Thanks man!
Eric
I'm glad to see you guys trying to develop stuff for the 3uz.
I'd love to see this stuff work out to make a bad ***, NA GS430.
A cam, intake and headers designed for a stout, NA 3uz would be sweet. I'd love to make my car an all motor 400hp GS without the pita of FI.
Originally Posted by jbrady
I hate to rain on anyones parade... but... that manifold will dramatically reduce driveability and low RPM power and response. High RPM power could possibly be increased but probably not much. For a high RPM ONLY application this could have merit. For a street driver there is definitely tradeoffs.
Eric
Eric
I'm late to the thread but I'm with Jay for the same reasons he mentions and more.
I wouldn't run this manifold if it was given to me.
Then I guess you're in luck because it won't be given to you. If you don't like it that's fine.. go build something better.
Eric
JPI
That's my point. And, clear to you perhaps, but the manifold was not presented that way.
I would expect some data to be posted up such as the comparison to a stock manifold, CFM flow numbers, a dyno run, etc. THEN people have something to base a decision upon.
Kevin might be the greatest guy around but the post is misleading and useless.
First sentence: WRONG!!! More airflow does NOT always mean more HP.
2nd sentence: MISLEADING. Any engine guy worth his salt knows that the SIZE of the intake runner (much like the exhaust, right JBrady?) is crucial to building a well balanced, top-performing engine.
Kevin never mentions that it's better for an FI engine over a mostly stock engine. Someone else did, but the poster of the product needs to say stuff like that.
I actually have some doubts that the manifold would even give decent driveability on an FI 4.0 motor. Racing?? SURE! Race the hell out of it. But vendors should be clear on these things up front, who the market audience is, and data on expected results after installation.
There are too many people who do know know what makes a good part or a bad part for improving their Horsepower/Torque for their driving needs.
The people that DO know, like yourself too JPI, need to help ensure that misleading info isn't taken as gospel. I think people here put a lot of trust in guys like JPI and TMEngineering, and the long, long standing members like DAVEGS4.
This isn't meant as an attack on you JPI because I wholeheartedly trust your shop and you do wonderful things for the guys on this board.
I have nothing against Kevin or his shop either, but, we don't want people to blindly jump on a product just because someone says "we all know more airflow equals more power!". It's misleading.
End Rant.
The manifold allows more airflow into the motor, and we all know that more equals more horsepower. This manifold is guaranteed to flow 25% more than the stock manifold, and is guaranteed to set your GS apart in both looks and horsepower.
End Rant.
Not always, but for the most part yes it does when balanced with velocity. Especially for the FI crowd which this manifold is catering towards.
Eric
If you would not run it, whats your point in coming in with negativity to someone else's idea and work. They never even got off the ground with it and you seem to be bent out of shape about it like you sent money in for it and it did not work, kinda like they owe you something.
Giv'em a break with the Drama. This is why there is so little performance aftermarket for the 1UZ vs. the 1JZ/2JZ ! Hope you don't mind if they test it on a car.
my god jgscott.
Did you not see a string of enthusiastic responses to an initial post that did not even contain target useage or application info?
Have you no concern at all for your board member brothers buying into a product without knowing how it will affect their actual driveability?
You know people do it. SRT Intake, Headers, Torque convertors, Supra rear-ends, all that good stuff. There are a lot of "non-gearhead" people on this board that will buy something without knowing (truly) the effects of it.
As I said, I brought to light the things that the original post did not, and they are VERY important things to know, that is all. I guess you don't even see that.
If you read the thread, you'd see that JB has the same concerns, he's just never been as direct as I will be. You just chose to single me out.
"I hate to rain on anyones parade... but... that manifold will dramatically reduce driveability and low RPM power and response. High RPM power could possibly be increased but probably not much. For a high RPM ONLY application this could have merit. For a street driver there is definitely tradeoffs"
We're getting there We want to revise it a little and then get to testing. But JGScott is right though. There's not much out there for the 1/2/3uz compared to the 1jz/2jz. Just intake pipes and headers. Oddly enough, there's an endless cavalcade of body kits and wheels. We'd like to change that but we can only do it with community support.
Eric
Eric
my god jgscott.
What test data do you have ? Seems like you hopped on the" me too " Drama Train. Like I said giv'em a Break til its tested on a car.
You haven't even seen the thing in person and you've already shot it down and done a test review write up on it.
Talk about some negative people on here. All I see are "If this and if that, I believe" etc. Obviously it is in development and we all have to start somewhere.
Man I sure didn't expect this forum to turn like a honda forum where people had to prove something and they were God gifted at engine modding. Lets get some numbers on it and we'll see what happens.
Eric
Eric
not criticisizing, just providing some feedback...
