Ok, I pulled everything off the car to replace my wastegate. This is what I found!
Moral of the story: get high temp lines for everything that's gonna be sitting close to the turbo!
Originally Posted by GS300rpf1
what engine managements are you running?
I'm running a MAP-ECU on my car right now. I was using a SAFC NEO at first, but it didn't work too well with boost. The MAPECU is much better and easier to tune. Oh and also with the MAPECU, the car is still fully driveable if any intercooler hose pops off
jeff: before you got the head gaskets to lower compression, how well does the wastegate hold up? is it safe to actually ride the wastegate all the time whenever boost hits 8psi?
That's an incredible write up. How long did it take you altogether? Also, would I get anymore power by running the SAFC-NEO on a stock GS3 with a cold air intake?
