IS300 Auto Transmission
Old 11-27-01, 01:37 PM
farajfad
farajfad's Avatar
Default IS300 Auto Transmission
I've got a 2001 IS300. I've been having problems w/ the shifting from 2nd to 3rd every once in a while. The shift is very jerky. I've heard that its a problem w/ the first IS300 made. I called my dealership, and they refused to do anything about it. And i called lexus customer service, and they said i have to duplicate the problem w/ the technician. Any of you guys know anything, or have any suggestions. Thanks
Old 11-27-01, 02:48 PM
Marley
Marley's Avatar
If your dealership does not know (or pretends not to know), about the update tell them to look up the following Technical Service Information Bulletin:
TSIB EG003-01
It has been officially released and available now. The update is a two part update depending on your problems, one is an engine ECU update program and the second is replacement of the TRAC ecu.
The ECU reprogram update affects all IS300s whose VIN number is LOWER/BEFORE 10025186
The TRAC ECU replacement affects all IS300s whose VIN number is LOWER/BEFORE 10029014
These is no specific Manufacture date but VIN number verification.
This was taken from the engine forum posted by MO from Swift Racing
Old 11-27-01, 04:17 PM
EmoDragRacer
EmoDragRacer's Avatar
ya knnow what is funny after my updates my tranny werked 10 times worse then it did before...POS I tell you the trannies are POS (pieces of ******)
Old 11-27-01, 07:27 PM
lexusrider
lexusrider's Avatar
Default DOESNT START AT 2ND
mine doesnt start in 2nd when i put to manual just after i started the car. i noticed this since it got colder. but after maybe a minute, or driving in auto, it goes back to normal. i can downshift to 2nd. does anybody experienced this? is it the intake/ecu, exhaust or just the weather. i need advices from the veterans here.
thank you.
p.s
the car runs fine.
Old 11-27-01, 10:38 PM
dpatterson069
dpatterson069's Avatar
what do u mean it doesnt start in second?? does it start in 3rd???
Old 11-28-01, 07:32 AM
Grey_is300
Grey_is300's Avatar
even if it says 2 when your in amnual mode it will start in 1st gear.. the numbers in manual mode just hold it to that gear. you can drive in manual in with 5 lit up and the car will drive as if you are in auto.. all it does is holds youto that gear so you can get more RPMs out of the grear.
Old 11-28-01, 11:12 AM
dpatterson069
ahhh!!!! i see what he was saying now!!! i get it..
i just didnt understand him before.. i was like "it doesnt start in second?!?!?! WTF!?!! maybe his car is jacked up..." but i get it now..
Old 11-28-01, 11:16 AM
liljungnam
liljungnam's Avatar
is a LEXUS supposed to have this many daymn problems with the TRANNY/ ECU. This shifting thing makes me paraniod.
i was wondering if anyone elses car idels @2000rpm in the mornings?
Old 11-28-01, 05:35 PM
ISzBest
ISzBest's Avatar
YA mine occasionaly will idle at 2k in the morinng, thats just engine warmin itself up. NO WORRIES! You coming to the meet friday right?
Old 11-29-01, 09:17 PM
lexusrider
lexusrider's Avatar
Default doesnt shift to 2nd at start
grey_is300
thanks! but why is it doing that,? i'm just worried maybe the ecu got screwed up with the srt intake i got including the ecu upgrade. i'm kinda afraid to go to the dealership coz they might void my warranty and blame it to what i did tap in the ecu. i'll probably take it off one time and put the stock back and see what happens. if it goes alright, my srt intake/ecu will be on sale.
Old 12-01-01, 12:27 AM
ISzBest
ISzBest's Avatar
I might buy it if u do sell it..keep me updated. thnx!
Old 12-01-01, 10:33 AM
EmoDragRacer
our tranny is stock form is a slush box
Old 01-08-14, 09:45 PM
gbphoto
gbphoto's Avatar
Default Hard Shift
I just put in a K&N intake on my 03 IS300. I have 130,000miles on it, but the air filter I installed tonight and now Im having had shifts between first gear and second gear anyone know what might be causing this?
Old 01-12-14, 07:51 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Wow, holy thread resurrection...
Did you install the mass air flow sensor the correct direction?
Also, is it a K&N brand, or a knockoff? The pipe also K&N brand or knockoff?
Old 01-13-14, 09:50 AM
gbphoto
gbphoto's Avatar
I believe so i put back on the same way it came off
and yes its the brand
and pipe is the brand also
Quick Reply: IS300 Auto Transmission
