Its ON six speed swap and all = Grip Industries
#61
duel 6-an fuel lines and clutch line plumbed in the front
![](http://i62.photobucket.com/albums/h103/grip2000/PICT0019-7.jpg)
Here are the fuel lines cooming together at the rear.
![](http://i62.photobucket.com/albums/h103/grip2000/PICT0017-5.jpg)
This last fitment is a go. Keep in mind this motor set does not just drop in as its from a supra. we were able to use a combination of motor mount brackets and with a few more tricks, Its in there where you couldn tell if it was factory or not.
![](http://i62.photobucket.com/albums/h103/grip2000/PICT0022-4.jpg)
![](http://i62.photobucket.com/albums/h103/grip2000/PICT0021-5.jpg)
after not liking the placement of the shifter on the last test fit we reworked the trans tunnel for a perfect fit.
![](http://i62.photobucket.com/albums/h103/grip2000/PICT0025-4.jpg)
#62
well this did not fly as expected,
![](http://i62.photobucket.com/albums/h103/grip2000/gs19.jpg)
I scored a diff from a gs400/430 and it is the correct gear needed for the 6 speed 3.2X. was hoping to use this supra lsd diff but the ring gear would fit over it. So im open diff correct gear for now.
#63
some more progress was made . Precision intercooler and some Grip custom aluminum pipes, along with a aftermarket aluminum supra radiator.
![](http://i62.photobucket.com/albums/h103/grip2000/gs1.jpg)
![](http://i62.photobucket.com/albums/h103/grip2000/gs2-1.jpg)
![](http://i62.photobucket.com/albums/h103/grip2000/gss.jpg)
getting closer every day
#65
there are some pictures on page 5...... After hacking away at my stock one i think we used one from a cressida/supra , (just the upright part ) as it was longer and was a better fit.
#66
Adam
#67
It clears the dead pedal pretty good , i was going to wait for a test drive to see if it becomes a problem. definatly looking to do a handbrake just have to find a few and see what i can come up with , maybee one fronm a SC would look at home?
#69
Good luck with the hand brake, I'll probably do that later in the year.
#75
I've been doing some reading on this, I guess you bought a 6 speed torsen diff? Everything I read on Supraforums stated that a NA Supra torsen LSD (rare) or a TT Auto torsen diff with fit right into that rear end, the 6 speed one won't work. I'm trying to locate a GS400 rear now, didn't the GS430 have a torsen rear from the factory? If so is the gearing 3.26?
