NA-T Sparkplug info...
This is for tthose that are FI. Just curious to know, what plugs everyone else are running with and at what gap?
I'm running NGK 6097
oops i forgot their gapped at 26
They are number 8. Very cold plugs. They suck on mornings when it's in the 50's. They are only like 2 dollars a plug but I have to change them a lot. I want some iridiums. Do you know of a good one? I'm running like 20lbs.
http://www.mkivsupra.net/vbb/showthread.php?t=41927
Hope this helps
Plug selection
Note - This selection list does not take Nitrous into account. If you have Nitrous go one grade colder than this table advises at your boost/performance level.
Normally Aspirated
NGK - Standard - BKR5ES-11 (2382) - gap 1.1mm
NGK - V-Power - BKR5EYA-11 (2526) - gap 1.1mm
NGK - G-Power Platinum - BKR5EGP (7090) - gap 1.1mm
NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm
NGK -OE Laser Iridium - IFR5T11 (4996) - gap 1.1mm
NGK - Iridium IX - BKR5EIX-11 (5464) - gap 1.1mm
Denso Platinum - PK16R11 - gap 1.1mm
Stock TT
NGK - BCPR6EP-11 - gap to 1.1mm PLATINUM
NGK - BKR6E (2756) - gap 1.1mm
NGK Iridium - BKR6EIX-11 (3764) leave gap alone
Denso Platinum - PK20R11 - gap 1.1mm
Denso Iridium - IK20 - leave gap alone
TT @ upto 1bar
NGK - BCPR7ES (3330) - gap 0.9mm
NGK - BKR7E (6097) - gap 0.9mm
NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone
Denso Platinum - PK20R11 - gap 0.8mm
Denso Iridium - IK22 - leave gap alone
TT/hybrids @ upto 1.3bar
NGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK24 - leave gap alone
Single Turbo/Big Twins @ upto 1.3bar
Single Turbo/Big Twins @ upto 1.8bar
NGK - BCPR8ES - gap 0.6-0.7mm
NGK - BKR8E - gap 0.6-0.7mm
Denso Iridium - IK27 - leave gap alone
Single Turbo/Big Twins @ 2+bar
NGK - BCPR8ES - gap 0.6mm ??? UNTESTED
NGK - BKR8E - gap 0.6mm ??? UNTESTED
NGK Iridium - BKR8EIX or BKR9EIX? - leave gap alone ??? UNTESTED
Denso Iridium - IK27 to IK31 - leave gap alone ??? UNTESTED
Information sources
Denso
NGK
Sparkplugs.co.uk
Personal experience
Previous discussions on this and other BBS's.
-Alex
Normally Aspirated
Stock TT
TT @ upto 1bar
Information sources
Denso
NGK
Sparkplugs.co.uk
Personal experience
-Alex
