Tranny Cooler...
#61
Sounds good, I guess mine is good to then... I wonder how much of a difference it made that i'm bringing it through the radiator AND the Hayden, cooling wise? As apposed to just the Hayden.
#62
Worse comes worse, it'll be good as the Hayden alone. Nothing to worry about. I think I'm going to re-run my hose so I utilize the radiator. Could come in handy when I'm at idle for a long time so that the radiator fan kicks in. Thats better than having no airflow into the tranny cooler at a standstill.
#64
Guys, everything on coolers has been discussed a great many times on this forum by prior owners over the years. Do a search.
I copied this from another site to save me the trouble of repeating things.
Often, external trans coolers are plumbed so that they replace the stock in-tank radiator cooler, but most OE and trans cooler manufacturers recommend retaining the factory cooler, using the external cooler to increase the system’s heat-transferring capacity. Proper routing passes the fluid through the radiator cooler first, then on to the external cooler before heading back into the transmission.
New Product RR-Racing ISF Radiator and Tranny Cooler Package
RRRacing
CL Vendor Products for IS-F
12
10-01-21 11:24 AM
