how to swap jdm turbos for the usdm turbos?is it hard to do? do i just take the jdm turbos off and put the usdm ones on? my second turbo was gone so i went ahead and bought a good used set of usdm ones. anyone know? how about a write up? is there any difference between the two sets other then the egr plumbing and the blades?
It will be a direct swap for the most part. I think the exhaust flange might be different but you should be able to just swap it from your old Jdm turbos with out a problem.
The Aristo Manifold needs a jdm or custom downpipe. The exhaust flange is different from the USDM. The USDM turbo's requires a more available downpipe. You can use the megan racing one which is like $129-$150. If you got the extra dough, I would recommend the Tanabe one which costs around $250-$275 but well worth it.
