Diy Hks Exhaust Install?
takes 20 minutes, 2 bolts a few hangers, the oem piece is all one piece so it makes it a little hard to get off. the new one goes on in the same hangers, a few bolts and gaskets and tighten it all down.
Real easy DIY. Especially if you have a lift or a friend with a lift to throw it on like I did. May need an extra set of hands to get the stock off it's a bit awkward and heavy getting the hangers off behind the bumper. But a little finesse will Git-R-Done. Other than that just make sure the tips are lined up right in the bumper notches before tightening up the bolts from the Y to the muffler. 30min tops.
taking off oem exhaust
1. jack up the car
2. put jack stands on the supporting brace
3. unbolt the exhaust pipe from the resonator (2 bolts)
4. spray WD-40 on the rubber hangers n take it off.
puting on hi power hks
1. basically reverse of removal
NOTE: put the hanger before bolt on, not bolting it on than hanger =D
1. jack up the car
