Intake noise question
I just installed a K&N Typhoon intake yesterday. I double checked to make sure everything is tight. When I barely tap the gas I hear a turbo wind like noise. Kind of like when you position your lips to whistle but instead of blowing out air, suck in air. That is the noise it makes when I barely give it gas. Kind of holding it at about 1700-2000 RPM in 6th gear. It sounds awesome at WOT, but am concerned I have a air leak somewhere. All I need to know is if this is normal. Please give me your thoughts.
Anyone else with the K&N Typhoon find it annoying, because I had planned on ordering one this week. Any K&N intake system I had on other cars did produce a sound like you are describing but I never found it annoying, so trying to determine if this is just normal or to what degree of annoying you are suggesting?
If you have double checked the install, then I would assume it is just normal....It is not a complicated setup. Part of the appeal of an intake, as well as any performance increase, is the increased flow of air and the being able to hear this. I would not worry, enjoy knowing your engine is breathing better. I am going ahead and ordering mine tomorrow. I have always been happy with K&N in the past.
When i was buying my is350 i test drove two different ones. The first i drove sounded AWESOME, at full throttle that thing wailed. I actually thought it was an exhaust while i was driving. When i got back from the drive i looked at the mufflers and they were stock. The next car i drove and the one i ended up buying doesnt sound anything like that at WOT. You all with the aftermarket intake say it sounds awesome at WOT above 3.5-4k rpm. What kind of sound is your intake make. The sound i heard wasnt a woosh/sucking/turbo noise kind of sound, this definitely sounded like exhaust, but like i said he did have the stock mufflers. I guess i may never find out, cant go back to the dealer and look around more since i already bought my is350 somewhere else. If changing the intake gives the engine noise i heard at the dealer ill definitely do it; might try to remove the resonated snorkel thats pre-air filter first. Another way i would describe the noise is the engine noise you hear during a car racing video game while revving the engine or something like that.
Can you guys describe the noise youre getting at WOT just from the intakes.
