Official Tranny Cooler Thread for the 2GS
Old 03-09-16 | 12:33 PM
  #196
sakataj's Avatar
sakataj
Originally Posted by sung35
I read the entire post from first to last, and still have not find any picture to indicate which line go where. I had the external transmission cooler install a while ago by Mo SRT. He bypassed the factory cooler. Now I want to remove the external transmission cooler and reconnect the transmission hoses back tot he factory transmission cooler. If anyone can help me out with pictures of where the lines should go, I am really appreciate it.
no way you read all that and didnt get your answer, i know you didnt cause i posted a pic AND the info about where it goes.....post # 158
Old 03-09-16 | 06:34 PM
  #197
sung35's Avatar
sung35
I saw that pic, and knew that the out line (straight) and the return line (bent), but it does not show where the ends of those hoses go to. I guess that it does not matter which connector it connect to. Thank you anyway, Sakataj.
Old 03-10-16 | 06:23 AM
  #198
Bhubb18's Avatar
Bhubb18
Where it pops out, one fitting is angled, towards one side of the radiator, the other side is straight, and that goes to the close side of the radiator. IMO bypassing an aftermarket cooler is silly, though.
Old 03-10-16 | 06:36 AM
  #199
sung35's Avatar
sung35
My thought exactly. Anyone new SRT should know Mo. He is a legit mechanic in MD. I did not know that when he installed my external transmission cooler he bypass the OEM.
Thanks for the input on where the line hoses should go. I am going with the route replacing the radiator.
Old 04-23-16 | 08:08 PM
  #200
MeenGrn02's Avatar
MeenGrn02
Originally Posted by sam430
would anyone wanna be a guinee pig and try this?
I'm new to the 2GS3 club, I've been studying all the fuss about transmission coolers. I've seen some good threads, the heat sink really intrigues me. Mounting location is the problem, there is real- estate in front of the condenser, more passenger side, the problem is that our license plates hang down too far, in front of the lower grill. At speed, the license plate creates a buffer that redirects air to the sides and below it, however the gap between bottom of the license plate and the bottom of the lower grill is not really big enough for sufficient air flow to hit the heat sink. There is one location left, but it involves clever mounting, directly above, upside down using slotted angle iron. This car will be seeing many more miles, 143K (new to me and immaculate), in Texas heat. Here we have 85mph speed limits, stock engine and trans combo revs 3K @ 75mph, vast heat is created when holding consistent for 5 hours at time. I like the efficiency of heat sinks, but I don't want to be slowing the flow of fluid when raising the cooler above the bottom of the radiator, but then again a dual pass sink will create less resistance than a core style cooler, so loss of fluid pressure might be negligible. I also like the sinks because they are more robust than a finned cooler, so they should theoretically last longer. I will be pulling the strings on this project within the next month, so keep an eye out.
Old 09-18-18 | 12:00 PM
  #201
Bscovronsk's Avatar
Bscovronsk
Default Aftermarket transmission temp sensor
Originally Posted by JeffTsai
sakataj, the cooler will connect to the stock trans oil cooler line. It's the two rubber hoses going into the bottom of the radiator. Just unhook those and run a new hose to the cooler. Or some people run a new cooler in line with the stock one to get double cooling.
Oh and did someone say transmission cooler(s)?
i'm looking for a work up or image of how to and where I can tie into my factory transmission sensor so I may install my gauge. Yes i'm a noob yes iv looked but I can't find anything outside of the internal wire harness please and help would be awesome
Old 10-29-18 | 03:58 AM
  #202
clubcaner's Avatar
clubcaner
In my case, the worse was drilling into the metal beam. Even then, all I needed was a drill and self-tapping screw.
Old 03-12-19 | 07:30 PM
  #203
GSpearlwht's Avatar
GSpearlwht
Hi guys.
would lucas transmission fix stuff be a good idea?
Old 03-12-19 | 07:31 PM
  #204
GSpearlwht's Avatar
GSpearlwht
Old 09-22-22 | 08:14 PM
  #205
Kiddchaos2's Avatar
Kiddchaos2
1st Gear
Default A little data for those unsure
I installed a Four Seasons 53008 transmission cooler today and wanted to share some numbers for anyone interested. It seems to be a reboxed Hayden 679, Hayden is stamped on it.
It is in line with the factory cooler, mounted on the passenger side of the A/C condenser.
During my morning commute we hit a max of 217F (stop and go) with cruising temps around 180-195, the fluid is fresh and pink, trans has 198k on it to my knowledge.
On the way home we hit a max of 170 and cruising between 150-160.
My commute consists of a bunch of country roads for the first half and then a transition to stop and go around 40mph.
I do have a P1755 code I need to deal with, but I'm not certain if that would effect trans fluid temp much.
sxs191
GX - 1st Gen (2003-2009)
02-11-17 10:54 AM
ShaneC
Performance
04-08-07 07:01 AM
blaznsc4
Performance & Maintenance
03-28-05 12:35 PM
Shyne
Performance
11-02-04 12:24 AM
