I want to change the differential oil..
Old 06-22-07, 10:37 AM
whazzzzuup
whazzzzuup's Avatar
Originally Posted by kmaynard
I am getting ready to do this also, dealer said it was dirty and wanted $50 (they are doing my 30k service). I told them no, of course.
I have the same question as Chenzo26, why use 75W instead of 80W?
Most of the products I've seen are 75W (synthetic). 75W and 80W differ very slightly.
The first number, with the W next to it (75 vs. 80) is the kinematic viscosity (thickness of the oil). 75W is a little thinner than 80W, which directly correlates to the warm-up time of the oil. It's a linear relationship. The thinner the oil, the faster it can get to operating temperature. The other positive linear correlation is: the higher the kinematic viscosity, the higher the protection. But the difference in viscosity is so minute that you will not be able to find differences between the two without specialized test equipment.
Old 11-09-07, 10:20 AM
jonathancl
jonathancl's Avatar
Originally Posted by tmf2004
Dash, will this pump fit other 75x 90 fluid containers? or just the amsoil fluid?
Even if it doesn't fit, you can still insert the pump and use it. Most pump kits come with several lengths of tube to for the bottom to adjust to different depth oil containers. I used one that didn't fit the container and had no trouble.
JonGS3 (08-01-20)
Old 05-31-09, 10:05 PM
pingu
pingu's Avatar
Did this today.
My experience with using the pump is that they take forever. I attach a hose and a funnel and let gravity do it's work.
Old 05-31-09, 11:56 PM
GS4_Fiend
GS4_Fiend's Avatar
Get the Long Life type from AMSoil and you will never need to change it again. 75w 90. Also get the pump from AMSoil, it fits perfectly. I recommend you get the car raised up on a lift and get a long pipe for assistance. It's a PITA if you are just using the Hex, actually I would say nearly impossible to do it with just the Hex. When I did mines, even with the long pipe attached to the end. I can hear it crack, creak, whatever the word is when turning the damn bolt. Also, get 2 washers for the bolts and GL.
Old 01-15-10, 06:11 PM
GSRSRT
GSRSRT's Avatar
i want to do this also right away but my problem is i noticed a leak on it can anyone tell me what to change on the differential to stop the leak?
Old 01-15-10, 06:16 PM
jcat_350
jcat_350's Avatar
for this you will have to remove the differential cover, scrape off the old sealant, and reapply a good bead of RTV sealant and reinstall. Also, be sure to replace the washers on the bolts.
Old 01-15-10, 06:56 PM
GSRSRT
GSRSRT's Avatar
THNAK YOU SOOO MUCH jcatGS3 i love this site
Old 01-15-10, 06:57 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Hadn't had a chance to do this yet but the new fluid goes in at the top of the differential right?
Old 01-15-10, 07:09 PM
On3_Lo35
On3_Lo35's Avatar
correcto
Old 01-15-10, 07:14 PM
tmf2004
tmf2004's Avatar
Originally Posted by On3_Lo35
correcto
Thanks... Is that a hex bolt also?
Old 01-15-10, 09:35 PM
jcat_350
jcat_350's Avatar
yes...and i'm not being a **** in saying this because it really is funny...picture trying to get the fluid to go in and stay in from the bottom....lol
Old 01-15-10, 10:19 PM
tmf2004
tmf2004's Avatar
Hey i had to ask LOL... Great reply..
Old 01-19-10, 04:43 PM
VipBippu08
VipBippu08's Avatar
i 2nd that.. Better than any fluid on the market today hands down!
Old 01-19-10, 05:10 PM
kennylexsc
kennylexsc's Avatar
I did my on my 2000 gs300 at 150k, it's the first time I ever done it, and I am glad that I just had differential oil done, it's good for the car and rear wheels or whatever anyways.
It used the mobil 1 gear lubricant,
Old 01-19-10, 08:11 PM
jjbenzo
jjbenzo's Avatar
Went to the dealership yesturday to put on a couple new tires. While I was there I picked up two new differential plug/bolt gaskets/washers b/c I am wanting to change out the fluid within the next week.
My question is this, I bought a bottle of Royal Purple diff. oil last year for my Supra, but ended up having the dealer do the drain and fill. So, now I have an unopened bottle in my garage. I would like to know what everyone's thoughts/experience is with Royal Purple. Is it better than others? Not as good as others?
Thanks in advance!
Quick Reply: I want to change the differential oil..
