Annoying very high idle after swap
Overall the car runs great. '98 GS300 w/VVTi 2JZ GT swap. It rips! One lingering problem...now more than before, the engine idles around 3000 rpm. I can't figure it out. Starting/turning it off repeatedly seems to be the only fix. You can imagine how much that process sucks.
I read a post hear about a temporary fix, but couldn't find it on the forum search function. Someone also suggested it IAC, but I'm pretty sure the Drive-by-wire VVTi engines don't have one. The ecu controls the throttle to compensate for idle.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Check that the coolant temperature sensor is working properly or is plugged in. The ecu changes operating modes according to the coolant temperature. If there is something wrong with your sensor, the engine may be stuck in cold start mode all the time. I had that problem when I tore apart my motor and put it all back together. I forgot to plug in the coolant temp sensor and my car was idling at 2500rpm+.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Get your own OBD2 scanner. A lot cheaper than going to a shop everytime you need to check a CEL code or other engine stuff...especially now that you have a totally non-factory car lol. I bought mine on ebay for like $200. It's a OBD2 scanner with a USB plug that you hook into your laptop. It has all the datastream modes and can also read all the Toyota factory scantool specific codes if you get that software package...it's pretty cool stuff. The brand I got is AutoEnginuity. However, I'm not sure if your car has the same interface and OBD connector since you have a JDM ecu lol.
Anyone with a new snapon reader with a Toyota adapter can read the car from the port under the hood.
I would look for a vacuum leak before going to all this trouble though.
Ben
Ben
Next time it does it try this, has worked 100% every time for me.
If you start the car and it rev's high immediately turn it off.
Turn the key to the ignition "on" position
Put the gas pedal to the floor.
Now turn the key off while holding the pedal to the floor.
Release the pedal, start the car. Problem should be gone.
I don’t believe he has the 2JZ-GTE, I am pretty sure we are talking about a 2JZ-GE with the OBD2 diagnostics. But this would be an important detail to know to be able to determine the solution. You definitely want to make sure there isn’t a DTC hidden and pointing to a bad sensor. And also if it was just a newer 3.0 but not a twin turbo the. It’s possible he didn’t swap the throttle pedal or something like that:
