custom Accufab TB setup?
I am interested in purchasing a custom Accufab TB setup from an IS owner. His IS is turbocharged but I was wondering if I could use this setup on my NA GS3? The TB is larger but I think the mani is stock. According to him, the butterfly inside the plennum is set to remain open. It also includes custom throttle cable brackets that allow me to use the stock cable. He also told me the I would need an safc, which I have, but he also mentioned that he is not sure if the stock computer can control the Idle Control Motor. Will it be able to control it and is it even possible to do this before I even consider buying this setup? If so, what problems may I encounter when bolting on this setup? Here's the link to the pic:
https://www.clublexus.com/gallery/sh...103390&cat=500
Thanks in advance.
Thanks in advance.
The ACIS butterfly valve is commonly removed or disabled for boosted cars. It causes a flow restriction and creates a lot of noise at high boost levels. It's supposed to help NA cars by closing it's acting as a makeshift long runner setup. At higher rpm's the valve opens changing the manifold to a short runner setup. As for that throttle body working with your stock ecu car or not...that all depends if he removed the drive by wire setup on the throttle body which I would say so because it's missing the motor and actuator. Really, there's not going to be too much gain from getting a bigger throttle body unless you're boosted. Cost benefit ratio...I say nay. Just get an aftermarket intake, header, SAFC, and get it tuned. That's about as good as you're gonna get with a GS3 N/A motor unless you spend some big bucks.
Thanks in advance.
Thanks in advance.
JPI
JeffTsai
12-11-11 08:25 PM
djkevin510
Performance & Maintenance
02-25-11 07:11 AM
twizted
SC400 / 300 Classifieds
19
06-21-09 05:02 AM
