O2 sensor questions on safc
if i remove all O2s the car will go into open loop and stay there, ect...
will the safc be able to overide the ecu on fuel trims in open loop? will i have problems with the ecu fighting the safc for fuel control? i have read how many people have to reset ecu to keep it from altering fuel trims on there piggy back fuel controllers sytems.
Are you running boost? If not then your SAFC adjustments should not be enough to trigger the stock ecu to fight back. If you're running boost then the amount of fuel difference will cause the ECU to trigger a CEL and fight the settings on the SAFC. The way I solved my problem is by pulling out all 4 O2's. The car holds it's tune exactly how I set it and never changes. The only real downside that I'm seeing is that since the ECU is running 100% open loop...it does not adjust to atmospheric fluctuations such as extreme temperature changes. Here in Texas it's 70F one day and 100F+ the next. The other downside is that obviously you won't be able to pass state inspections, but we all know "someone" don't we?
It's all about tuning and how much more boost you're running. If you run just like 7-10psi or so and match the injectors correctly, then you should be able to tune within the ECU's acceptable parameters. The GS4/430 ecu is probably quite different compared to the programming in the GS3. The GS300 ecu is very very touchy and hard to tune in the ecu's range...especially at higher boost and rpm levels, stuff starts to get whacky.
SC300T
Performance & Maintenance
18
09-24-02 09:53 PM
