Final: Injen or Weapon R
Originally posted by 400DGRZ
SWEET!!! I like the clean aluminum look.
Originally posted by RacingAristo
I heard that Injen had a recall on their IS300 intake. I wonder why....
First I want to say I would never ever buy an intake with a foam filter and put it on any of my cars so that nocks WR off my list.
If you need more reason then that check out this website.
http://www.gtrowner.com/induction.html
If I were you I would get the SRT HFI because it is the best intake out there bar none. However if you were set on WR or Injen I would get Injen.
The Injen intake for the IS300 was recalled because the IS300 has ODB II computer and that cause problems the check engine light came on, because of the more aggressive filter they made originally for the Intake, so the fix is a replacement filter. The second gen intake from Injen for the IS was made to fix the ruff idle which caused stalling problems, the first one had. They also added at that time a heat shield and larger diameter pipe.
Originally posted by LexusRules
they are pretty much the same except:
Weapon*R is cheaper
Weapon*R has a better filter
plus if u want the weapon*r ecu its an option as well... but ur gett S-AFC rite?
Weapon*R is cheaper
I can prove my point but, would love to hear your's...
