Why am I losing power???
#31
I may be wrong, but typically when you start bolting parts on a car while on a dyno, you get higher gains with the additional air. (Lean condition) As soon as the ECU adjusts with more fuel, the power usually levels out. This is one of the reasons I usually drive a few hundred miles before I dyno parts and this is typically how some after market companies make power claims.
#32
As I've mentioned several times, the dyno run files would tell us a lot about what happened. The WinPEP software is downloadable, so you can view the data yourself if you have the data files from your dyno shop. I always bring a blank 3.5" floppy when I do dyno testing, and don't even bother getting paper copies.
See if the shop will email the data files to you. The things that we need to know (from the data files) is the run speed during the test (will tell which gears were used for each test), and the ambient temp and barometric pressure (will tell us if their sensors flaked out between tests and gave a bad SAE correction).
Sorry, but I don't trust your butt dyno at all for a 10 hp / 10 ft-lbs loss.
#33
haha..i hope my butt dyno is wrong too. i may not feel 10ft-lbs but i should feel 20, right?
i will see if i can get the data file from the shop today. i think i will wait to put the stock airbox back on after i put a few more miles on it. ive been around 250 miles so far.
#35
We aren't talking about 20 ft-lbs anymore since the dyno wasn't done properly. By testing the way you did, the dyno operator was obviously giving partial throttle until he got to very high RPMs or the transmission would have downshifted. If you look at the plot above 5000 RPMs, you only lost about 10 HP and 10 ft-lbs. The area down below just needs to be ignored.
You shouldn't reset the ECU because you've already driven enough for it to relearn everything. If you reset it, it will have to relearn everything again.
#38
Tech Info Resource
^^and that's why I won't even guess why the OP got the result he did.
#40
#41
#42
anything about backpressure is bull****.
the purpose of adding an intake is for more air flow. Exhausts are installed for allowing exhaust gases to escape. The faster gas escapes, then less work your engine has to do.
