My GS300 74mm Turbo'd
thanks, there is a video here of me beating a newer Mach 1 Mustang that was running 12.1 @ 110 at Speedworld the night I raced him, soonafter this video I cracked a ringland on my stock pistons after turning up the boost to 24 psi on my old T60-1, nearly every ringland was cracked but no damage occured to the block or head.
I'm looking forward to making some nice power with this setup.
http://www.youtube.com/my_videos
74mm turbo and you are running on 440cc injectors? Better get those upgraded.
Also, a quick word of advice. You cannot run any larger than 720cc injectors with the MAP-ECU on the NA ecu, because you can't control the injectors at idle. 720's are probably even pushing the limit.
The max you can run with a pig back is 550cc. Unless you know how to play with valve jet. With this kind of hp it would be wise to have a stand alone in place. Methanol can't control all the timing you need. It's a quick band aid solution. You would need to find a way to disconntect that OCV so your timing won't reach sky high when reaching high boost.
JPI
JPI
JPI
JPI
A 320 system can do about 640cc, a 440cc system can do 880cc and a 550 can do 1100cc and so on.
can't remmeber what stock N/A injectors are, but rule of thumb is about 100% larger injector is the max.
Thanks.. From what I have read 525cc's is really all the stock computer can handle, I got a good deal on the 440's so I'm staying with those for now, I have a Haltech E8 in my closet and a set of 1000cc injectors however I want to see what I can do on the stock ecu. I have a friend who runs 800RWHP on stock 550c injectors and meth injection on his Supra, right now I have it set up at 12 psi on the 440's and its running great, I'm going to take my time inching up the boost. I got the headlights on Ebay, they're great!
