Na-t
I'm running on stock injectors now, and want to turn up the boost.
When going to bigger injectors, Say 500-550cc. What brand and what should I look for when purchasing one. I've heard that our Lexus GE injectors are differnt then the Supra GE.
Also what EMS do I need to control the bigger injectors besides FPR, and bigger Fuel pump?
I'm sorry if this sounds rude, but I was only asking about wich 500-550cc injectors are good for the 98+ GS3. Also the model number would be good too. I didn't ask for a return line plumbing answer or RC was good on my honda.
On that note I hope this doesn't sound rude. Use the search function or check out manufacturers that are offering turbo kits and see what they use. If you are familiar with performance at all you would recognize that RC engineering has been around a long time and the person above was saying that they worked well on his car, the injector doesn't care what car it's in to base how well it will work.
Every single question above can be answered using the search function on this site.
There have been a few posts here about it...probably written by me lol.
Anyways, I used RC Engineering injectors. It doesn't matter what car you use it in...a good injector is a good injector as long as it fits. RC Engineering and Precision are two good domestic brands. Only downside for those is that you have to splice in new injector connectors, but that only takes like 20 minutes. For japanese brands, the one that comes to mind is SARD injectors. They're basically rebadged Denso's. You can get the SARD 550cc direct drop in injector...even the power clip will click in.
Also, you will have to run a return fuel system if you plan to flow more fuel. A new fuel pump is required. A rising rate fuel pressure regulator is also highly recommended. As for the engine management, I'm using the MAP-ECU with good results.
If you're gonna stick with the RC Engineering injectors...you will need the SL4-550. You will also need custom sized gasoline resistant o-rings so they will fit on the fuel rail. I happen to have some available for sale http://sr1.clublexus.com/forums/showthread.php?t=285618![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Fuel Return setup with fuel pressure regulator writeup by me. Still incomplete...too lazy to finish updating it lol.
http://sr1.clublexus.com/forums/showthread.php?t=286338
You shouldn't belittle those trying to help you out. That will only make people reluctant to helping you out in the future.
When going to bigger injectors, Say 500-550cc. What BRAND and what should I look for when purchasing one. I've heard that our Lexus GE injectors are differnt then the Supra GE.
Like I said "Im sorry if It sounds rude". It didn't mean to offend people on helping me. I've been around CL for a while and am not a Noob. I know how to use the search button. I searched for injector(s)/injecter(s). Nothing came up on 2nd GS3 NA. Was mainly looking specifics on any other GS3 owners that have done this upgrades on forced induction.
I a have the FPR(Fuel Pressure Regulator) plumb in with -6AN supply, and stock line as return. but have not hooked up the new FP as I have to make hangers for it. I'm running 5-6psi now and would like to turn it up to 12-15psi with new injectors.
THANK YOU JEFFTsai. That was some good info.
boosted-gs i just bought 380CC denso injectors i'll let you know how they go...
How much are you planning on boosting with 380cc. Are they direct swap with out midifcation to the rails? Please keep us updated, and thank you for the info.
98Quicksil i had some rc injectors on a 2001 turbo honda prelude a few years ago and they seemed to be very good.
I apologize if that offended you. I was only looking for 2jzge specifics and should've noted that.
You could also use the 440cc from a MKIII with the MKIII resistor box or buy the resistors from Radio Shack for about $5 for 6.
You will also find alot of info over at www.clubna-t.com
