Whats that noise
Not sure if this post will get moved but since most people seem to reply here, here it goes. I just installed the Tanabe to the IS350 and sometimes, I hear a pop, almost like a small backfire when I slow down. This doesn't happen all the time but once in a while and it's not loud but its there. Is this "normal" break in of the exhaust? I never had this with the stock but only after putting on the Tanabes. Could it be I didn't tighten something or had to do some extra step during install? Could I have a leak? The only 2 places the leak could be I guess is where the exhaust connects to the existing pipe on the car and also where the 2 Tanabe pieces connect. I noticed they did ship what appeared to be a metallic like gasket for in between where the 2 Tanabe pieces connect or is this for where the Tanabe connects to the car? Was I even supposed to use this gasket that was shipped with it or are the connections ok without anything in between them? Sorry I can't be more specific but I am sure that the folks who have Tanabes will know what I am talking about.
One thing I noticed or didn't notice was that some people posted that they had smoke and funky smell for the first few minutes of running after the install. I had none of this, could the exhaust I have be faulty?
The gasket that comes with it is to connect the two Tanabe pipes together. For me the smoke was for the first drive but the smell lasted a whole week. How log did you drive it for? To check for big air leaks just put your hand close to the two connections to see you can feel anything. Just do it when the engine is cold as to not accidentally burn yourself.
I retightened the bolts and drove around for a bit today and so far no more pops, only time will tell. I also read that if the pop occurs during slowing down, it's most likely a leak somewhere.
On another note...When the car is still in "Cold Mode" like when your motor is not to the halfway point yet, my motor pops when I try to get on it...I think it's some kind of dummy proof thing that "retards" the motor/timing until it is fully heated. My terminology might be wrong but I know I'm headed in the right direction with it Haha
