RMM supercharger 8psi Dyno numbers for TX Mode Parfume GS4
Just want to thank Jason and Annie over at JPI for their hard work and patience while my car was getting worked on in their shop. They are an A class company. It was definately worth the 3 hour drive up to have them do work... He will be installing the JPI headers tomorrow and we'll be back on the dyno!
on to the car-
376 WHP 330 TQ
performance mods
Mode Parfume Exhaust
RMM supercharger w/ intercooler
custom return fuel system by JPI
Snow Meth Kit
custom pulley work by JPI
running 8PSI
THE VIDEO
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/th_Thomasdyno378.jpg)
THE DYNO SHEET
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/dyno1.gif)
There's more to the setup buy I'll have Jason from JPI tune in and add the other things.
on to the car-
376 WHP 330 TQ
performance mods
Snow Meth Kit
running 8PSI
THE VIDEO
THE DYNO SHEET
Thomas we picked a really good day to dyno your car
. The temp in that dyno room was 107 degree. It only took 3 runs to dial in the right AFR. First run it was a little too rich. So I took some fuel out and some meth/water also. It's not done yet. The headers are coming on tomorrow. BTW, That meth kit works very well.
JPI
JPI
Rev limiter. I had my eyes on the boost and AFR gauges. It pulls strong all the way to redline. AFR stays rock solid at 11:1 with meth/water injection in the mix. People said meth/water tuning should be around 12:1 and I don't believe in that. I want to leave some room for safety!
The split second does an excellent job for partial throttle. Since our stock computer like to stay in the 14.7 range, Split second modified 02 sensors signal so we won't have any problem with partial throttle tuning.
JPI
JPI
We were installing the JPI headers today. Passenger's side fits without any problem. We ran into some issues with the driver's side, The steering shaft is very close our header. Keep this in mind, We fab these headers from the stock units. The longer runner would have to move 1/4 of an inch back for it to clear. Some changes move have to make to the main jig that we built.
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1606.jpg?t=1188434137)
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1615.jpg?t=1188434641)
A/C compressor would have to remove for installation on driver's side header. While you are at it remove that oil filter and the header will slide right out.
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1610.jpg?t=1188434849)
Transmission dip stick would have to come off. The 12mm bolt sit in a very hard to reach spot.
Oil dip stick coming off also.
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1623.jpg?t=1188435142)
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1632.jpg?t=1188435052)
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1624.jpg?t=1188435177)
Since the exhuast nut stuck on there real quick. We don't have any choice but cut that stock manifold.
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1625.jpg?t=1188435236)
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1627.jpg?t=1188435272)
Plasma cutter do come in handy
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1631.jpg?t=1188435316)
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1633.jpg?t=1188435345)
Stock Vs JPI headers
![](http://i135.photobucket.com/albums/q159/jpi1/Thomas%20GS400/IMG_1634.jpg?t=1188435414)
Here is the problem that we ran into. Like I said, we shifted the headers 1/4 of an inch toward the back.
I will upload the videos later tonight.
JPI
