Info on GS300 manual swap
Does anyone have any info / pictures of the GS300 with a 5 speed or 6 speed swap, I remember seeing a couple of cars with the manual swaps but I can't find any info or pics now. I'm swapping a R154 with a 1JZ bellhousing into my GS300, I would like to see where past owners mounted their clutch master.
I used to own Auto Tuner, my shop built Nick Hogans green Supra. There isn't much fabrication, just install the bracket to hold the clutch pedal, mount the pedals, and drill a coule of holes for the clutch master, make some brake lines up for the master. The hardest part will be to fab up a custom center console piece but I'll probably have a stereo shop do that for me. Oh and custom make the driveshaft is another $500 or so.
We have a local MKII with a R154 5 speed making over 800RWHP so these trannys are stout. I've already done the GTE internals, 74mm PTE turbo, Haltech, 1000cc injectors, TRD LSD, and IC / Meth injection...
I'm in Orlando
I'm running a haltech
I'll get back to you when its done, right now I'm at
$450.00 tranny R154
$1100.00 Champion Toyota parts (1JZ Flywheel, 1JZ Belhousing, pedals, clutch master, slave, etc...)
$550.00 RPS 6 puck MAX series clutch, good for 700RWHP
$450.00 tranny R154
