Ecu???
Old 09-24-07, 05:29 PM
Cak067
Cak067's Avatar
Default Ecu???
whts would u recommend for an ecu for is300
Old 09-25-07, 07:17 AM
Gernby
Gernby's Avatar
Wrong forum. Sounds like you should post this in the First Generation IS forum.
Old 09-25-07, 07:18 AM
Gernby
Gernby's Avatar
Better yet ... do a search in the first gen SI forum...
Old 09-25-07, 08:13 AM
Bichon
Super Moderator
Bichon's Avatar
Thread moved.
Old 09-25-07, 01:41 PM
juniorsdad
juniorsdad's Avatar
ecu..?
are you asking about a stand-alone..?
or possibly a safc..?
a lot depends on the engine mods you have....
Old 09-25-07, 04:43 PM
Cak067
Cak067's Avatar
aem intake
exhaust
mayb injectors
whts a good ecu to use...cause i just got a lexus is300 and wana do a ecu chip now i heard unitech was good but i just wana get peoples opinions
Old 09-25-07, 04:48 PM
Gernby
Gernby's Avatar
Originally Posted by Cak067
aem intake
exhaust
mayb injectors
I don't know who "mayb" is, but you don't need aftermarket injectors. Even after installing intake and exhaust, your engine will still be running too rich. You would be fine with a piggy back ECU to lean it out some more.
Old 09-25-07, 06:12 PM
Cak067
Cak067's Avatar
yeah dude i know
i would mayb do injectors after i do ecu
i just wana know whts a good relyable ecu
Old 09-25-07, 06:33 PM
Gernby
Gernby's Avatar
ecu run great better yeah.
injector ... intake
good ... mmm..
Old 09-25-07, 08:01 PM
MisterCam
MisterCam's Avatar
there's really no ecu chip you can get for our cars. You can get the ecu from srt that's already tuned, which you solder on to the stock ecu. Or you can get a SAFC-II to tune the air/fuel ratio. Better yet you can get a Engine management system like an Haltech F10X, EManage Ultimate. These will let you tune the air/fuel ratio, raise the rev limiter, let you set settings for when your reg driving, idle or even WOT. Check into those options.
Rock-a-Lex
Performance
09-12-07 01:28 PM
jy2003is5spd
IS - 1st Gen (2001-2005)
11-16-02 12:03 AM
BLiu
04-02-02 11:09 PM
peterm1
Performance & Maintenance
10-18-01 09:53 PM
Quick Reply: Ecu???
