Cold Air Intake.... Any Japanese manufacturers?
Old 10-20-07, 09:51 AM
j stuff
j stuff's Avatar
Default Cold Air Intake.... Any Japanese manufacturers?
I have been looking up intakes and all i can find is
SRT
INJEN
K&N
Are there any companies based in japan or made in japan that make cai's?
edit: sorry mods, wrong section!
Old 10-20-07, 01:02 PM
kevs98GS4
kevs98GS4's Avatar
akimoto makes one.........but lost power on my dyno run so i sent it back!
Old 10-20-07, 03:07 PM
cliffud
Former Vendor
cliffud's Avatar
you forgot LMS
Old 10-20-07, 07:59 PM
GSteg
GSteg's Avatar
j stuff, none of those intakes are cold air intake. They're all short ram intakes. I dont know of any CAI for the GS as of right now, unless you custom make the pipe.
Old 10-20-07, 09:00 PM
cliffud
Former Vendor
cliffud's Avatar
I'm pretty sure my LMS instake is a cold air intake. It's much longer than the short ram...
Old 10-21-07, 12:12 AM
j stuff
j stuff's Avatar
Thanks for clearing that up GSteg
Old 10-21-07, 12:31 AM
GSteg
GSteg's Avatar
LMS intake only applies to the GS300 though. I dont know if they make one for the GS400.
Old 10-21-07, 11:05 AM
cliffud
Former Vendor
cliffud's Avatar
yeah, i've never heard of an intake for a gs4. you V8 owners have enough power, just leave the engine alone.
Old 10-21-07, 12:52 PM
Lexizm
Lexizm's Avatar
You are correct, they only make them for the 300.
Old 10-21-07, 06:58 PM
GSteg
GSteg's Avatar
Never!
After awhile, 300hp feels slow
Old 10-22-07, 06:07 AM
Rock-a-Lex
Rock-a-Lex's Avatar
I made mine from my K & N FIPK! Just extended the piping into the wheelwell. Since my install I was getting a CEL because of the larger and colder volume of air entering and passing the MAF sensor so I shortly reverted back to the original K & N FIPK setup (like SRT setup) and built a cold air box...which is also very good but the extended CAI is by far much better ONLY if you have an A/F tunner (controller) like the Apexi Neo which I just bought. I will be reveting back when I get this tunner installed. The car was running lean with the CAI extension the tuner should clean this up. We'll see.
Previous setup but going back to very soon...
Attached Thumbnails Cold Air Intake.... Any Japanese manufacturers?-p8140156.jpg
Old 10-22-07, 07:56 AM
dcz
dcz's Avatar
notice any performance difference with the cold air?
Old 10-22-07, 08:39 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Yes! Definitely but at low RPM it seemed to "spool" (like a turbo lag effect) slowly; probably because I was running lean (CEL popped up on dash) due to the extra air flow. But I tell you with this setup it kicked in hard further up the RPM band. BTW, last time I had this setup was before my PI TC and 3.76 LSD so I felt this "lag". Now I'm sure I wouldn't feel any loss of low-end acceleration with the addition of these goodies. However, I would not recommend this mod without an A/F controller (Apexi SAFC II / Apexi AFC Neo) because under hard acceleration you WILL trigger a CEL (check engine light) to come on making your car run lean and not run at it's proper potential. BTW, MANY members suggest this setup IF done correctly is MUCH better than the SRT with race ECU because SRT's piggyback ECU is NOT tunable whereas the above referenced A/F controllers are allowing to squeeze out more HP and TQ.
Old 10-22-07, 12:31 PM
cliffud
Former Vendor
cliffud's Avatar
(quietly chants)
dyyyy-no! dyyyyy-no! dyyyyy-no!
Old 10-22-07, 01:01 PM
kevs98GS4
kevs98GS4's Avatar
(quietly chants)
+1..........
Quick Reply: Cold Air Intake.... Any Japanese manufacturers?
