nos?
Old 11-02-08, 06:03 PM
  #241
HKS350
HKS350's Avatar
Just thought I'd update. Ran the 1/4 mile today.
Time : 12.55 et
MPH : 109.65
Mods : Intake, Exhaust, custom midpipe, SAFC, & 80HP shot of Nitrous.
Old 11-02-08, 06:28 PM
  #242
Gernby
Gernby's Avatar
DAYUMM! Was this on street tires? Any weight reduction?
Old 11-02-08, 07:17 PM
  #243
HKS350
HKS350's Avatar
^ Weight reductions : spare tire & floor mats only. I was on 20" wheels 275/30/20 Nitto NT555. I have a video in the IS-F sub / Nat drag comp.
https://www.clublexus.com/forums/sho...=382064&page=5 post #71.
Their is alot left in her also. I have room in tire setups, better DA, and more weight reduction. On my next try I'll have a drag tire setup and pull the pass. seat.
Old 11-03-08, 06:13 AM
  #244
nabbun
nabbun's Avatar
sa-weeeeeeeeeeeeet run!
now let's talk about NOS in my car
Old 11-03-08, 10:08 AM
  #245
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
Time : 12.55 et
MPH : 109.65
I guess Jeremy gets James' c/t now
Old 11-05-08, 04:40 PM
  #246
Lextasy89
Lextasy89's Avatar
wow nice run.. when did you move up to an 80 shot, is it a custom nozzle?
Old 11-05-08, 05:07 PM
  #247
JohnnyIS25
JohnnyIS25's Avatar
whoa very impressive, i have only a 50 shot and i am afraid of using that already LOL
Old 11-05-08, 06:21 PM
  #248
HKS350
HKS350's Avatar
Just for this last weekend. I bought a jetting kit and have been trying out various HP settings. The IS seems to really like the 80hp jetting. Jet size N2O .41 and Fuel .22
Are you wet or dry? And don't be worried about it.
Old 11-05-08, 06:30 PM
  #249
iSuxeL
iSuxeL's Avatar
You have a 250?
Old 11-05-08, 06:33 PM
  #250
JohnnyIS25
JohnnyIS25's Avatar
Originally Posted by iSuxeL
You have a 250?
yep, that why it make me afraid lol, and its a wet kit, but really mainly just for looks cause of the polished bottle
Old 11-05-08, 06:38 PM
  #251
iSuxeL
iSuxeL's Avatar
Won't that really bump compression to like 14:1 or higher?
Old 11-05-08, 06:49 PM
  #252
caymandive
11 Second Club
caymandive's Avatar
The compression ratio won't change with N20 unless it changes your piston's face, bore, or combustion chamber volume at the same time.
Also from what I have heard N20 seems to like engines with higher compression ratios.
Old 11-05-08, 06:56 PM
  #253
iSuxeL
iSuxeL's Avatar
That's weird, I was told it pushes compression that's why nitrous makes power.
Old 11-05-08, 07:01 PM
  #254
caymandive
11 Second Club
caymandive's Avatar
As I understand it basically cylinder pressure is how much pressure is placed on the cylinder walls from the explosion. Compression ratio is how much the material in the cylinder is compressed before the explosion.
Cut and paste off the web to answer the power question:
"When you heat nitrous oxide to about 570 degrees F (~300 C), it splits into oxygen and nitrogen. So the injection of nitrous oxide into an engine means that more oxygen is available during combustion. Because you have more oxygen, you can also inject more fuel, allowing the same engine to produce more power."
Old 11-05-08, 07:09 PM
  #255
iSuxeL
iSuxeL's Avatar
Hmm...good to know about nitrous. Thanks James, I wasn't disagreeing with you, just telling you what I was told. I see you ran 12.4 now? Nice!! Sorry off topic
Quick Reply: nos?
