nos?
Old 12-07-07, 10:15 AM
  #121
caymandive
11 Second Club
caymandive's Avatar
Originally Posted by Lextasy89
i tried to find more info about this^^ but didnt really get anywhere.. but I had just heard the 2.25" would be better for torque and 2.5
' would be better for hp on our cars
hp and torque are directly related. You also have to remember that you can't always believe everything you hear or see on the internet.
Old 12-07-07, 10:17 AM
  #122
Lextasy89
Lextasy89's Avatar
ha yea i know.. but I meant more along the lines of low end toruqe vs high end hp.. but also talking to Taylor at Dallas Performance he told me the same thing when I was talking to him specifically about different size tubing.
Old 12-07-07, 11:24 AM
  #123
HKS350
HKS350's Avatar
Update.. Finished exhaust. I did go with an X-pipe after all. And 2.5 " pipe. Not to tread jump to much It got rid of all the dead spots in the power band. Butt dyno doesn't feel much change. It is just alot smoother through the rpm's. And sound awesome.
Old 12-07-07, 11:38 AM
  #124
carlos
carlos's Avatar
what components did you go with for the exhaust?
I had my 2 secondary cats removed, 2.5" piping all the way through, magnaflow x-pipe and magnaflow mufflers.
Old 12-07-07, 11:51 AM
  #125
Gernby
Gernby's Avatar
If you have any pictures and / or video of the new exhaust, please tell us about it here.
Old 12-07-07, 11:57 AM
  #126
carlos
carlos's Avatar
i wanted that x-pipe as well... but damn that thing is $$$$. good stuff.
Old 12-07-07, 09:01 PM
  #127
combfilter
combfilter's Avatar
Jeremy , what is your (if any) experience with Nitrous Express systems? A lot of my friends have their setup and like your zex system it seems to be well respect. I mostly ask this question because I get it so cheap thru my friends ss trailblazer sponsorship.
Old 12-09-07, 07:00 AM
  #128
HKS350
HKS350's Avatar
A NX Kit is a great kit. Just make sure they have a kit with fuel psi rating in the 50-60 psi range. I went with the Zex because it has a TP sensor wire. On our cars this is a must. I actually like other kits better than Zex, But the easy install sold me.
GrizzlyMan (04-18-21)
Old 12-09-07, 10:49 PM
  #129
iceman1117
iceman1117's Avatar
YOU ARE CRAZY! and my new IDOL lmao....We NEED to see some videos when you get a chance.
Old 12-10-07, 03:56 PM
  #130
Chirodan
Chirodan's Avatar
Originally Posted by Gernby
It really wouldn't surprise me at all if a 55 shot would break the tires loose in 1st gear even with drag radials, but you would have to be on some crappy tires or roads to have a problem in 2nd gear. If the tires can handle 300 HP at the crank in 1st gear, then they should be able to handle 500 HP at the crank in 2nd gear.
My Z06 would break loose in 2nd gear and it just had a little over 400 hp. A friend's Viper was stock and would easily break loose in 3rd gear while getting on the highway and it was only 500hp car. I don't remember what the tq #s were on these cars but were very close if not the same.
Old 12-10-07, 04:06 PM
  #131
Gernby
Gernby's Avatar
I had it wrong. The thing is that HP really has nothing to do with breaking tires loose. Thrust (from torque) is what causes tires to break loose. After thinking about it, it is obvious that a 50 shot at 2000 RPMs could easily break the tires loose since it would be increasing torque by 150+ ft-lbs.
Old 12-10-07, 04:20 PM
  #132
Lextasy89
Lextasy89's Avatar
^^ a 50 hp shot increase your torque by 150 ft-lbs???
Old 12-11-07, 06:56 AM
  #133
Gernby
Gernby's Avatar
It could if you sprayed at low RPMs. You have to consider that the N2O system delivers a constant amount of fuel and N2O regardless of RPM. That means that the concentration of N2O in the intake charge goes down as RPMs rise. The motor would probably blow up in an instant if you sprayed while at idle in neutral.
Old 12-11-07, 07:50 AM
  #134
HKS350
HKS350's Avatar
Here is a little food for thought. Fuel cut at revlimiter, But you still have fuel and N20 spraying. Motor over revs. and spin bearings. Or floats valves. This would be more likly to happen in neutral.
Old 12-11-07, 07:53 AM
  #135
caymandive
11 Second Club
caymandive's Avatar
Jeremy you going to utilize a window switch to ensure the N20 stops spraying before hitting the rev limiter?
Quick Reply: nos?
