When should i get a new spark plugs...
well ive been talking to guys that treat there car like an amusment park... dwn here in cali...they say every 2 oil change...or simply when they are worn out...how can you tell?? im a novice in terms of mechanical talk..
They're Denso Iridiums. I've heard 35,000 miles, not the 100,000 that platinums are told to change. I scanned the manual and supplement and didn't really see anything specific. The Denso site says 60,000 miles.
They are Iridium denso spark plugs and their service interval is at 60k service. Look it up in your owners maintanance manual. You should only use OEM plugs for replacement. The plugs are abot 2 times longer than the standard plugs and no one makes replacement plugs that will work right. The plugs is designed this way since it has to be placed in the exact center of the combustion chamber. The fuel is injected directly onto it from the direct injectors.
-Joe
-Joe
Here is the information that I found:
EG-130 ENGINE — 2GR-FSE ENGINE
3. Spark Plug
Long-reach type spark plugs are used. This type of spark plugs allows the area of the cylinder head to
receive the spark plugs to be made thick. Thus, the water jacket can be extended near the combustion
chamber, which contributes to cooling performance.
The triple ground electrode type iridium-tipped spark plugs are used to achieve a 60,000 miles (100,000
km) maintenance interval. By making the center electrode of iridium, it is possible to achieve superior
ignition performance and durability when compared to platinum-tipped spark plugs. Furthermore, two
ground electrodes have been added to further improve ignitability, wear resistance, and fouling resistance.
3. Spark Plug
yea anyone get those sparkmaster plugs? or whatever they changed there name too
edit: torque master spark plugs.. or extreme spark
