mazzuri super headers
#182
Received 1,064 Likes
I was also confused when it was mentioned that "they are different"..
When all this time we are told they are the same???
My guess is the OEM ones are the same, but the aftermarket headers will have to be designed/sized just a bit different between the IS250 & IS350
Then I guess we will also have to wait & see how the O2 sim works, if the IS350 ends up throwing a CEL as well..
#186
Tech Info Resource
Properly sized primaries for the 250 would kill top end on the 350. It might still work and be more mid-low torquey, but top end would surely suffer compared to a properly sized primary.
#187
#188
The OEM headers are exactly the same, my headers are different. The difference is in the collectors not the primaries. Early on my.is I mentioned that the Megas are huge for the 250 with their 1.75" primaries and that the 250 needs 1.25" primaries to make the most power. I unfortunately do not have tooling to bend that, so i went with 1.5" which is perfect for the 350 and again why I say, I have no dough the 350 will make huge numbers.
Also, technically, if the headers was made with 1.25" primaries for the 250 it would make even more power. This also goes for the IS300 which ideally needs the tube to be somewhere around 1.35 ID.
#190
Yeah, unless you put the stock ones back on. As for Lexus, the only thing theyc an void as far as warranty is your exhaust warranty. That's it.
#192
how do they differ in the collector? and how does that effect each one?
glad u have the tools for the 350 primary size. or should i say that it happens be a nice number
#193
I can't say what the difference is in collectors, but each one is made to work correctly with the motor of the 250 or the 350.
#194
Tech Info Resource
Are you using a custom built collector or off-the-shelf from someone like Burns Stainless?
