mazzuri super headers
Old 03-02-08 | 11:45 AM
  #211
Lextasy89's Avatar
Lextasy89
you guys think tuning the engine for the best air fuel ratio would help alot after getting some mazzuri headers??
Old 03-02-08 | 11:48 AM
  #212
jimmyjazz's Avatar
jimmyjazz
Yes it would. But you can't crack the codes to do it.
Old 03-02-08 | 01:46 PM
  #213
ba-b4's Avatar
ba-b4
so why is the toyota ecu so hard to crack again? I have a feeling the uncrackable new GT-R's ecu will be cracked before ours is...
Old 03-02-08 | 01:52 PM
  #214
AznJason's Avatar
AznJason
Why do you need to crack the codes? Doesn't Gernby have a piggyback that does Air/Fuel tuning?
Old 03-02-08 | 03:35 PM
  #215
Lextasy89's Avatar
Lextasy89
i dont think you need to crack the codes to simply use an air/fuel controller
Jermey (dude with nitrous) has one
Old 03-02-08 | 04:15 PM
  #216
jimmyjazz's Avatar
jimmyjazz
From what I understand, to do a true "tune", alter the a/f tables and the timing tables, at differing rpm's you need to go into the computer. You would only alter these variables at full throttle or closed loop settings. In regular driving on open loop the standard settings would be used. If you could open the computer these could be adjusted also. From my experiance watching LSx engines, they all ran rich after a header install, so the computer has to take away more fuel for the proper O2 readings just cruising around.
Old 03-02-08 | 06:21 PM
  #217
as3.0cl's Avatar
as3.0cl
because there is a lot of security that goes into a toyota ecu. the GT-R will definitely be cracked shortly just because there is a market for after market parts for this car because of it's following.
all you really need to tune air and fuel ratio's is an APEXi Neo and tap into the stock ecu, i know someone one here has one hooked up. that is all you can really do, other then that timing ect can not be changed.
Old 03-03-08 | 06:51 AM
  #218
Gernby's Avatar
Gernby
If this header is any good, then I would expect the AFR to be leaner than stock after installing them. I've never heard of a good performance mod causing a rich mixture on an NA setup. I've always believed that a piggyback ECU is generally most beneficial on a stock vehicle, then slightly less beneficial with each good mod after that since the unadjusted mixture gets closer and closer to optimum with each mod.
Old 03-03-08 | 09:01 AM
  #219
Lextasy89's Avatar
Lextasy89
hmm well it would be nice to expect that. but its nice to know we have options likfe using and SAFC if thats not the case
Old 03-03-08 | 09:29 AM
  #220
mazzuri's Avatar
mazzuri
The IS300 headers all run in the 10:1s when the header is installed and most pick up another 10 hp or so when leaning it out.
On the IS250 the ratio was a bit lean, I think it was mid to low 14:1s on the low end, top end however it was down to 11s.
I think the biggest gains on this car would come from tuning the timing, as it was all over the place on the dyno if you just mashed it.
Old 03-03-08 | 10:56 AM
  #221
05LSV's Avatar
05LSV
Would tuning the timing involve cracking the ECU?
Old 03-03-08 | 11:00 AM
  #222
kacerr264's Avatar
kacerr264
You can definitely tune the air/fuel because I have a greddy e-manage ultimate piggy-back and i have been able to tune those numbers. I cant wait to get these headers on and see if a retune is going to help.
Old 03-03-08 | 11:02 AM
  #223
Lextasy89's Avatar
Lextasy89
nope..........
Old 03-03-08 | 11:16 AM
  #224
Gernby's Avatar
Gernby
I wouldn't feel at all comfortable altering ignition timing using a pigg-back ECU (e-Manage).
Old 03-03-08 | 11:19 AM
  #225
Lextasy89's Avatar
Lextasy89
^^ explain.. you have a custom piggy-back ecu...
Quick Reply: mazzuri super headers
