mazzuri super headers
#376
They are made from Stainless Steel, so rust won't be a problem and like Jetstream said, you don't see them on our cars so I wouldn't even bother coating them..... they turn a really nice gold color after a few miles.
#379
But will coating them make them last longer in our cars? How's the durability compared to stock headers? I've always heard aftermarket headers wear out faster.
#381
I have no idea how much air flow that area gets to know if heat is a real concern. From what Daniel has said it's real tight working in that area though, so there's not much breathing room. And now knowing they are made of stainless steel gives me less concern over weathering.
Daniel what's your opinion on coating?
#382
To split hairs, yes it would help with the longevity, but the headers should outlast the car regardless if you had them coated or not. I'm no expert, but main reasons to coat would be for the heat protection, styling (which i don't care much about with this car), and then there's some debate if coating would help a tiny bit with the performance.
#383
Could I ask anyone to post a few DIY pics or instructions for removal of the OEM and install of Daniel's... I have a set coming for my 250 RWD and I am pretty good with tools and my hands and have an impact wrench, but not extensive air wrenches... What has to come off in what sequence and what tools (special or otherwise will I need)?
Thanks in advance...muchas gracias
#384
Many headers wear out because they are mild steel and rust on the outside from moisture and corrode on the inside from exhaust gas and moisture from the heat cycles, that's one of the advantages of getting the inside and outside coated. Mazzuri's are stainless steel so you don't have to worry about rust and corrosion like a mild steel, although it still slightly exists. Coating the outside of s.s. headers would help with the underhood heat, though.
#385
exactly what kind of coating are we talking about here? just wrapping them up or are we talking coating them in that aluminum suspended in a resin coat that i've seen on a Rides built or two?
#386
#387
Tech Info Resource
Jet Hot's explanation of how it works is not based in any science at all, but the coating does actually work to keep velocity up and underhood temps down. It also helps light up your cat faster if you are leaving any cats in the exhaust, so your cold cycle emissions are less.
This is the same reason you want to coat turbo headers - turbos are driven by waste heat. The more you let absorb into the header, the less goes into driving the turbine.
#388
So what's the general consensus on coating the headers? I can't see it making a dramatic difference as far as performance, so it really comes down to a question of heat protection in my mind. I have no idea if that's really needed with our cars or not. Sounds like Daniel tested his out and ran with them not being coated. Assuming if there were concerns of ambient heat he would have mentioned that...
#389
hey i am a newbie at doing work to my car, and i am really interested in these headers, will it void my warranty? and will it be damaging my cel etc or car? basically to make things short is it 100% safe for the car? and not damage any parts
#390
What this means is that if, for example, you put in an aftermarket HID headlight kit, they could possibly deny warranty coverage if there's a wiring harness problem they could show was related to the aftermarket HIDs... but they can't deny warranty coverage if something went wrong with your rear brake calipers.
With the headers they could probably deny warranty coverage on a decent range of engine problems, but you'd still be covered if, say, your navigation system stopped working.
