mazzuri super headers
Old 04-21-08, 04:45 PM
  #496
Gernby
Gernby's Avatar
Thanks for doing the test! PayPal sent.
I wonder how much of a role the altitude could be playing here. I also wonder if the issue might be due to the design choices that were made for the stock manifolds. Even as crappy as they are, maybe they are much better suited to the 350s than they are the 250s, which would make the headers much more beneficial to the 250s. ... These are just wild guesses...
Old 04-21-08, 04:46 PM
  #497
Gernby
Gernby's Avatar
... then there's the possibility that the dyno test of the original 250 could have been flawed ...
Old 04-21-08, 05:13 PM
  #498
Toptier
Toptier's Avatar
Originally Posted by combfilter
Thanks Toptier. We appreciate you sharing this info.
BTW, how many dyno fund donations did you end up getting?
I ended up getting 2 for a total of $60
A big thanks to you and Gernby for the donations
Old 04-21-08, 05:17 PM
  #499
Toptier
Toptier's Avatar
Originally Posted by caymandive
Judging from the dyno it doesn't appear full throttle was applied until after 4300rpm. So the data to the left of 4300rpms may not be of much value. I assume 4th gear was used for all runs, but what mode was it in? (snow/norm/pwr)
You did gain some power though not much, so my only assumption is that the secondary cats and rest of the exhaust may be holding you back from the full potential of the headers.
Thank you from all of us for doing this unbiased testing.
I was done in 4th gear in snow mode
Old 04-21-08, 05:40 PM
  #500
Lextasy89
Lextasy89's Avatar
the stock exhaust and secondary cats doesnt seem to hold back much power from the IS250.. so why would it for the IS350?
Old 04-21-08, 05:47 PM
  #501
carlos
carlos's Avatar
So much for that power increase guarantee.
Old 04-21-08, 05:50 PM
  #502
Lextasy89
Lextasy89's Avatar
im depressed now..
Old 04-21-08, 06:20 PM
  #503
Gaugster
Gaugster's Avatar
Toptier, It might be a mute point but did you happen to get any Air/Fuel ratio data this time around?
Old 04-21-08, 06:53 PM
  #504
Toptier
Toptier's Avatar
here you go.
Old 04-21-08, 07:04 PM
  #505
HKS350
HKS350's Avatar
Wow on the A/F ratio. You were lean until @ 6100 rpm. You'll never make any power at 14.0 even 13.5 is a little risky. 13.0 Will provide good HP numbers. I'd be a little concerned with how lean its running. The HP could be down because the ECU is seeing the lean cond. and pulling timing.
Old 04-21-08, 07:09 PM
  #506
HKS350
HKS350's Avatar
Notice at 4.9k when it jumps up to 14.0 how the Hp drops. Looks like the best power is made somewhere between 13.0 and 13.5 A/F
Old 04-21-08, 09:01 PM
  #507
05LSV
05LSV's Avatar
bummer.....
Old 04-21-08, 09:24 PM
  #508
ndk83
ndk83's Avatar
hmm... disappointing i guess, we all had such hihg hopes but lets wait and see what daniel says/ is gonna do. Hopefully this can be adjusted. This my be selfish but for me this is a good thing, well now know the difference in design and restrictions between the two models.
On a happier note, you gained torque which as stated is better than high end HP and compared to every other mod for our car this is still the best mod for the car in dollar to power terms ( well that adepends on how many dynos you do,)
Old 04-21-08, 09:37 PM
  #509
ndk83
ndk83's Avatar
noob question:
how would one adjust the air / fuel ration since there is no ecu tuning. Does the ECU ned to adjust on its own? Will it over time?
are we saying the A/F curve is too flat and that it shoul decrease alot more alot earlier in the rpm range? or should the same slope remaing the same but just alot lower ont he graph?
Old 04-21-08, 09:56 PM
  #510
ba-b4
ba-b4's Avatar
Wow so little gains for so much work AND becoming illegal. No thanks. I'll bet that if you just delete the cats off the stock headers you'll get the same or better gains.
Quick Reply: mazzuri super headers
