mazzuri super headers
Old 09-03-08, 06:59 AM
  #1066
Gaugster
Gaugster's Avatar
Originally Posted by fluxx
actually the headers were originally designed for the IS250 rwd and they work great. Other variations were adopted because of demand.
I think that ndk83 was refering to the stock manifolds being purpose built for the IS350 and then used on the 250s regardless. That's been my theory for some time now. I am not having much luck with the AWD version but am looking into a solution.
Old 09-03-08, 07:00 AM
  #1067
juice14
juice14's Avatar
Originally Posted by erikbaker
When I was running the headers on my 07,350 I gained something like 7 hp and 35+ wtq. The dynos are some where in this long thread. I removed them because I started having misfires. After removing the headers my car has ran perfectly. I am not sure why I showed the most gain out of 350's then started having the misfire. Maybe my ECU rejected the headers after a while, and started running too lean. On my dyno charts the AFR looked good. But, I obviously wasnt misfireing at the time of the dyno. I can say, I felt a difference with the headers. I installed the headers and uninstalled them three times. The first time I didnt notice an increase, I think it just took the car some time to get used to the headers. The other times I felt the increase right away.
I am currently interested in installing my headers onto another 350. I just need someone to commit to it. I have been in PM's with someone on this thread. I hope to eventualy install them on his car.
I would buy them for you if i didnt have an 08 model.
Old 09-03-08, 07:45 AM
  #1068
Kurtz
Kurtz's Avatar
Erikbakers dyno results are here-
https://www.clublexus.com/forums/sho...&postcount=632
The results are completely unreliable however since the "stock" plot is obviously not valid (hp and torque do not cross at 5250 as physics requires them to)
They do cross at 5250 on the "after" graph but given both are from the same dyno we can't really trust either result...
I vaguely recall the dyno flat out broke right after one of these pulls so it was certainly already unreliable during the pull.... I think this was the "stock" one, done on a different stock IS350, as EB didn't dyno his own car before the headers (which makes comparing them even less usefull).
So no offense at all intended to EB, but his results can't really be counted as proving any specific gains at all given the dyno problems and the fact we're not even comparing the same car
Old 09-03-08, 07:59 AM
  #1069
erikbaker
erikbaker's Avatar
The dyno broke after the other 350 that is true.
I did however eventualy dyno my car after removing the headers. This was done on the same dyno so take it for what its worth.
The graph is a little off on the first dyno, but the numbers, I was told are acurite. It is just the location on the graph that was off. The guy owes me another dyno pull because of this. Check out post #790, that what I came up with after all this...
Old 09-03-08, 09:50 PM
  #1070
ndk83
ndk83's Avatar
yup you understood correctly, thanks. Been following ur story/posts on my.is Good luck with that
Old 09-04-08, 07:41 AM
  #1071
Gaugster
Gaugster's Avatar
Thanks, my Tanabe should come in the mail today.
Old 09-29-08, 05:30 PM
  #1072
passnu2
passnu2's Avatar
Is mazzuri still on here? His PM box is FULL I need some custom work done if anyone knows how to reach him please PM me that info.
Thanks,
Old 09-29-08, 05:38 PM
  #1073
javyLSU
2IS OG
javyLSU's Avatar
Have you tried searching Google for Mazzuri??? They have a phone number and everything...
Javier
Old 09-29-08, 06:13 PM
  #1074
rli2bcz
rli2bcz's Avatar
wierd thing happened today. after having the headers and the sim chip working fine for about 8k miles, the cel finally tuned on for the first time. has this ever happened to anyone else? how did you fix it?
Old 09-30-08, 06:34 AM
  #1075
Gaugster
Gaugster's Avatar
I have a bit less miles then you on the headers but no CEL.
How do you know it is related to the headers? Did you read the code. I guess my point is that it could be some other problem that is not related with the headers.
Old 09-30-08, 09:18 PM
  #1076
rli2bcz
rli2bcz's Avatar
oh well, got it fixed. just had to reset the ecu
Old 10-06-08, 09:59 AM
  #1077
Gernby
Gernby's Avatar
Resetting the ECU to clear a DTC without first pulling the DTC code is an irresponsible thing to do.
Old 10-06-08, 06:08 PM
  #1078
rli2bcz
rli2bcz's Avatar
then what should i do?
Old 10-06-08, 06:31 PM
  #1079
Gernby
Gernby's Avatar
Now that you've already cleared the ECU, you need to wait until it comes back, then pull the DTC code with an OBDII scan tool (Free service at AutoZone).
Old 10-08-08, 10:00 AM
  #1080
iSuxeL
iSuxeL's Avatar
So I guess these headers failed? I haven't heard anything about these for a while now. I still want the first gen headers for the tq though
Quick Reply: mazzuri super headers
