safc neo installing issues
Old 01-18-08, 05:36 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Originally Posted by GS FONZy
Neo does not have knock sensor input, but all the other connections should be fine. The only difference is the RPM and TPS locations.
Let's just pretend if these were reversed and I didn't catch it...can my engine go "kaboom?"
Old 01-18-08, 12:16 PM
GILLEXUS
GILLEXUS's Avatar
Oops i've never seen the NEO instructions. I thought that it had all the S-AFCII features and more. You say the RPM and TPS locations are different do you mean the harness you had made is different than the diagram you posted??
Old 01-18-08, 03:38 PM
GS FONZy
GS FONZy's Avatar
No beacause it only input.
Originally Posted by GILLEXUS
Oops i've never seen the NEO instructions. I thought that it had all the S-AFC features and more. You say the RPM and TPS locations are different do you mean the harness you had made is different than the diagram you posted??
If you compare the diagram on the Safc and Neo, the only pin connections that are different are RPM and TPS.
(Pic) red dots are for NEO's pin location.
Old 01-18-08, 08:58 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks for the re-assurance buddy! I feel so much better now!
Old 01-20-08, 11:59 AM
GILLEXUS
GILLEXUS's Avatar
My advise, I would go with the diagram that I posted from GURU I know that it acually works and the 10e diagram is tha same as GURU's that does work on the 98-00 GS400. To validate this fact go to SRT's ECU's diagram for the 98-00 GS400. SRT 's diagram has been working for dozens of guys.
You will notice that the RPM location is the only thing that is different w/ SRT's compared to Apex's 10e and GURU's diagram. What I found out researching the GS430 ECU for my S-AFC II install was that Both RPM's are correct.
SRT's RPM wire goes to the car's ECU ignition #1 output and the S-AFC's RPM wire goes to the car's tach signal.
Attached Thumbnails safc neo installing issues-srt-gs400-wire-diagram-large-.jpg
Asi
07-13-10 12:36 PM
DriftGirl
08-15-07 06:14 PM
Belshe1993
04-27-06 07:39 AM
Kharizma
01-26-06 01:25 PM
Quick Reply: safc neo installing issues
