Flashing the engine for more power?
Old 01-13-08, 07:21 AM
Joeb427
Joeb427's Avatar
Default Flashing the engine for more power?
I had a brief conversation with a guy who I believe said had a VW GLI and had the engine 'flashed' for more HP.
I've never heard that term but he said it was some engine computer imput changes that produced more power.
Can this be done?
Old 01-13-08, 08:33 AM
Lextasy89
Lextasy89's Avatar
probably never.. but if someone could ever crack the code to the ecu.. then yes
Old 01-13-08, 08:46 AM
Joeb427
Joeb427's Avatar
He seemed to say it was a pretty common thing in the VW crowd he's in.I'll get to talk to him sometime soon and will get more info.
Now that you mentioned the ECU,I think he said something about sending it out somewhere....
I'll find out more just for the hell of it.
Seems like no doubt void warranty issue.
Old 01-13-08, 09:43 AM
Lextasy89
Lextasy89's Avatar
its pretty common with most all cars.. very easy to do... just no one can do it with Lexus
Old 01-13-08, 11:02 AM
Irishman06
Irishman06's Avatar
Not only that, but there's a lot of complex stuff going on in the 350 because of the direct and port injection.
If anyone ever cracks the encoding, it'll still be tough to decode what the engine is actually doing and get it to make more power.
Old 01-13-08, 12:54 PM
carchitect
carchitect's Avatar
You could leave your injector or ignition coil disconnected with the engine running and it will flash the check engine light for you when its misfiring too.
We already have a shift light no your tachs I'm not sure why you would ever need this mod.
Old 01-13-08, 01:11 PM
DiauR1
DiauR1's Avatar
flashing the ecu to a NA engine "generally" does very little in terms of performance. IMO not worth the $$
Old 01-13-08, 11:45 PM
kattanh3
kattanh3's Avatar
Finally a performance aspect where I feel that I have an advantage over the rest of you lot lol.
The 2Gen IS300 sold in Asia & Middle East excluding Japan are w/o direct injection. With the main complex part out of the way, does this mean that the encryption is my biggest challenge? isn’t TOMs offering an ECU remap? Let’s ignore the fact that it is ridiculously expensive and only works on Japanese IS350s, I think the decryption method would be identical… I am really not experienced as all the remaps/reflashes I’ve encountered were simple plug&play’s.
If anybody can suggest something please pitch in.
Old 01-14-08, 04:02 AM
carchitect
carchitect's Avatar
I'm pretty sure the IS300 sold in asia is the same as the 06 GS300 3GR-FSE 235 hp engine. That engine does indeed have direct injection. It is the D-4 injection so it only has direct injection and no port injection just like the IS250's 4GR-FSE here in the states. The IS350 2GR-FSE is equipped with D-4S which is both direct and port inection.
Old 01-14-08, 05:02 AM
kattanh3
kattanh3's Avatar
Originally Posted by carchitect
I'm pretty sure the IS300 sold in asia is the same as the 06 GS300 3GR-FSE 235 hp engine...
no, it's uses the 228 hp 3GR-FE not the 3GR-FSE, the S here stands for the direct injection. I don't know about "port injection" though.
Old 01-14-08, 05:32 AM
is250awdnj
is250awdnj's Avatar
Tuning software and recording data. Tuning with those two things and you can make it run better not just once but anyday if you wanted to. "Reflashing" I believe is just another way of saying tuning to make your car run better or more efficiently.
Old 01-20-08, 11:47 AM
suicidesam
suicidesam's Avatar
here's a link to technosquare
http://www.technosquareinc.com/lexus.htm
might want to call them and find out if they have a re-flash for th isx50
Old 01-20-08, 01:24 PM
Joeb427
Joeb427's Avatar
I just emailed them.
I'll post what they reply.
Old 01-24-08, 03:01 AM
Joeb427
Joeb427's Avatar
Their reply:
No, we are not working with Toyota/Lexus ECU right now.
Sales
Technosquare, Inc.
Old 01-24-08, 05:36 AM
19psi
19psi's Avatar
reflashing a factory turbo car is a good easy way to make a significant increase in hp and tq. it basically increases boost and leans the wot a/f target some from the too rich but safe factory tune.
n/a cars it's not as dramatic, as the only thing you can do is lean it out a bit and maybe add timing. depending on how aggressive the factory tune is, n/a cars get 10-40 hp usually.
Quick Reply: Flashing the engine for more power?
