Thinking about a GS
I have owned two LS400, One SC300 and one SC400. I am seriously considering getting an older GS400 and stroke it to 5.2L and run it N/A. I put a 4.7L (Low compression) in my SC400 and its a beast. It jumped about 45 rwhp in hp and lot more in rw tq. With 5.2L and high compression going to be a very nice daily driver. SS headers and Cams will make this GS scream.
Here is a little vid from my current setup.
Accelerate from a dead stop
Imagine the setup is 5.2 with high compression, cams and exhaust.... WOW WOW.... WOW>... I just think the GS is damn sexy.... LS was great but the image is too mature....
As for me I need to allocate my budget about $6,000 for the motor and about another K for the cams. I also need to reserve some money for the installation of the engine. In my area I can get it done for about $500 (In and Out). So that is my budget right now. However, I would also need a piggyback to fine tune it. Money been tight, so I am slowly saving up for this. I also have another twin turbo project currently so time and money need to be carefully plan. Here is a picture of my stroker crank.
![](https://www.lextreme.com/Stroker/crank%20001.jpg)
And here is picture of my crank with custom rod:
![](https://www.lextreme.com/Stroker/crank%20006.jpg)
I am pretty confident with this combo my FUTURE GS will out run the new GS.
Of course your new GS with outrun the '08+ GS'.
Not sure why my pictures didnt come out. Anyway, I will need a piggyback to alter Air/Fuel due to aggressive cams and increase cubic from 4.0L to 5.2L. All modern EFI engine need EMS. NA or FI. The question is why type and why. Therefore, EMS is NOT only for FI application.
I understand now...thanks. GL with the project! If a stock GS400 has around 235-240whp what #'s do you think you could reach with all this work and no other work? Maybe 280-290??? Add a crap load of bolt-ons (Intake, exhaust, headers, SAFC/Neo) and you will be pushing 325+whp (~400hp @ the crank)....reliable NA!!! Awesome!
I really dont have any objective data at this time. Couple things about the GS400 that is good. It has very high flow heads. I have a friend with the Mustang 5.0 heads from AFR compare to the VVTi 4.0. The 4.0 flows better then aftermarket Mustang heads. So that really tell u something. If i have to take a rough guess on this. Here is the break down:
Increase Stroke: 30-45 rwhp
Cams: 30-35 rwhp
Increase compression: 20-25 rwhp
Tuning: 10-15 rwhp
Conservatively speaking around 100 rwhp gain is possible and torque will be massive from idle to redline. I would think torque be around 150 rwhp additional to stock and very street friendly too. So i gotta save up....
Cams: 30-35 rwhp
Tuning: 10-15 rwhp
GL on the GS project man. keep us posted, i am very interested in following your progress with this one.
have you upgraded any of the internal engine components in the 5.2 stroker in your 95 LS??
So what I am to understand is you are going to come out with some cams that no one has made. Bore the engine and some how tune it which I havent seen anyone do. And you are going to do this because you think you know some stuff about the V8 vvti lex.
From what i know no one other than the most professional ppl have done it in the last 10 yrs?
I hate to be negative but the GS 400 is alot different than the older projects you have worked on in the past. You cant just walk up to this engine acting like its the same as the old 1uz....
OOO and your going to do all of this on a budget to.... sorry if I cant see this happening. I hope you succeed but I remain skeptical. GL
Can't wait finally see a stroker on the GS
