Lextreme GS430 Owners inside!!!
Im trying to find some Lextreme TC owners that have a GS430, According to Lextreme thier torque converter doesnt give off a CEL light like the precision industries does. Anyone here have one of these converter's?
Its been over 2 years since I had a lextreme tc in my sc400. I'm not sure if there is a revision or upgrade to the one before, but mine seem to worn out in less than half of year. It makes sense since its a stock TC that reworked.
The TC from Lextreme are stock ones that are opened up and reworked to a higher stall. Kind of like "stock cams regrinds" where they weld on more material to the lobe and "rework" them to the custom lift and durations you choose. Over time, they get worn out. Its not the same as having a one piece billet core to start out with. If you have one, I'm sure you will feel the difference as I did.
I don't know if the Lextreme TX are built the same way anymore, since I been out of the lexus scene for some time now. This is not a bashing on their product either. Its a couple hundred vs. close to a grand for a aftermarket precision, etc. It would be a different post if they tried to charge the same price as the aftermarket stuff. You get what you paid for.
Hmmm lets see... The car felt great with the TC upgrade, did what every other owner experience with a TC upgrade. Then it felt like...stock again. It was worth it for the time I enjoyed my car. Lextreme does offer a warranty on it, but it wasn't really worth it to me spend another couple hundred buck to remove and have it installed again. By time you add everything up, you could have bought a name brand one. You know, even stock ones wear out and you don't need to see pictures to know it. Its a wear part. What could you do?
I was trying to see what symptoms you got that gave you the idea that it was the tc and not something else. What stall speed did your tc have? what was the stall speed after six months? When was the last time you serviced your trans? Have you checked your compression? When was the last time you changed your plugs? Did you have your car checked out when you noticed the issues? Sorry for all the questions, but I just want to meke sure that all other possible causes were eliminated?
2800 isnt a high stall speed at all....besides most people run a transcooler.
lower gears??? dude you got it backwards... im not going to give up my top end for low end. doing sixty mph in high rpm because I put in lower gears isnt what im looking for.
anyone else?
anyone else?
2800 rpm is considered a high stall speed for our V8s. It's practically almost half of our bandwidth anyways. Anymore of that and then you run into the risk of diminishing returns. Then again, anything is considered high stall when compared to the 1800rpm unit
I think someone said that if you run a 2600rpm stall, you wont get a CEL. 2800 might be too high for what the car wants to recognize. There aren't too many GS430 owners with an aftermarket torque converter.
