So I drilled
#77
I read this thread too and just to put my thoughts out there I think that those ridges on the inside are just there to collect dirt. It is common on a lot of cars to have that design. Air gets sucked up hits the air filter and drops back down and collects between those ridges.
Most likely it wont be a power gainer but it does add sound for a nice effect.
Also some people were talking about why there wasnt an open air element if it makes more power. Well just like the stock exhaust its quiet
#78
I've read this whole thread trying to figure out which intake to go with. Only one person said he liked his K&N.
Can a JOE Z with a drop in aftermarket hi-flow filter match the 11 hp gain of a K&N Typhoon? K&N are pretty good with they're R&D. See attached link http://www.l-tunedparts.com/product/?id=2804
Looks like the best of both worlds, sound (I've used them on other cars) and hp. Comments?
An open filter element won't do any better than a closed filter element because the -stock- intake already provides more air than the engine is capable of using. And in some cases it'll do worse because it'll be providing hotter air.
#79
I assure you the only person to measure an 11 hp gain on a 2IS from a K&N intake is K&N.
2nd, The Typhoon is a true Cold Air Intake as it comes with a box and sucks air through the same place the factory box did.
3rd, I'm not promoting them, I was just curious what other members thought of them as I'm in the market for something and I want the best.
#85
Am I the only one to notice the twin bumps in FS's intake that helps deflect it a bit. The original fins looks like they are helping to guide the airflow and is most likely there to help dampen the noise. I've noticed that most designs are for the target dB levels and performance for the general mass.
That said, I find it very funny that another thread is debating just a few horses. I wish someone would creatively find a way to get more power...
#86
Any negative affects to this yet?
I just picked up a F-Sport Exhaust last week and have a Joe Z on the way. I wouldn't mind some intake noise to complement the exhaust.
#87
in the process of doing the same... one question: on the side of the lower intake box, there's a wire running along the side. i tried pulling it out and stuff but i cant get it detached from the lower intake box. any suggestions?
#89
Tech Info Resource
Actually if you turn it over you'll see two small catches on the sides in the long direction. Squeeze them in gently with a pair of pliers and the wire mount will come right out of the hole. Pulling on it will very often break the clip.
