How to: Install JoeZ Intake 06+ 2IS
Be sure to do it... drove the "break in" on a drive to Chicago & back... averaging 31mpg now at 72-75mph... as far as the windows needing to be set, just walk around to each window, do a quick up & down, you're good to go...
Tech Info Resource
The flowbench taught me looks aren't everything. Sometimes things that look really bad flow really well. Nascar makes over 450 hp with four 1" square cut holes in a metal plate. That's 12.5 square inches total, but because they're square cut, they flow like 3/4" holes, so the effective area is a whopping 7 square inches. So, effectively, they're making 450+ hp with a 1.5" intake tube.
Our intake is WAY more than twice that area. So how big a tube do you really need to make 306 hp? Not very big at all...
You can buy it from our CL vendor carson lexus.
https://www.clublexus.com/forums/sho...ight=joez+dyno
JoeZ dyno test results:
LSin75033
11-16-18 01:47 PM
