Need intake advice
Old 04-29-08, 09:30 AM
Bigwun07
Bigwun07's Avatar
Default Need intake advice
Alright guys... I'm gonna be needing a air filter for my 2000 gs300 soon which usually run around 50 bucks but for 80 bucks i can buy modular air intake from Spectre Performance. On their website they have it where you can buy the seperate pieces and just put them all together. I know its not a SRT or an Ingen but his looks like a pretty decent one. There is the website below, check it out and lemme know.
Thanks
http://www.spectreperformance.com/#CATALOG
Old 04-29-08, 09:57 AM
jamodeo
jamodeo's Avatar
Truthfully, I would just go for the K&N FIPK or SRT with ECU, you can find members selling them in the classified section... Much better quality, plus a reliable name.
-Joe
Old 04-29-08, 04:39 PM
masboy
masboy's Avatar
-Joe
^^ ditto. stick w/ K&N or SRT intake....imho. Do it right or just don't do it yet..
Old 04-29-08, 05:48 PM
Downfall75
Downfall75's Avatar
There is no K&N intake for the 2000 GS 300. The best bet would be to go with the SRT. I suppose the only downside of the SRT is that its not carb approved, but other than that, its a good intake.
Old 04-29-08, 06:49 PM
4ntvings
4ntvings's Avatar
there is no k&n intake for the I6, only v8. ask yourself, what direction do you plan to take your car? if performance minded, then yes, SRT. if not, dont bother. really how much will an intake really give you? GL!
Old 04-29-08, 07:35 PM
DarKnight
DarKnight's Avatar
Get an Injen and an SAFC-II.
Old 04-30-08, 12:01 AM
swat1727
swat1727's Avatar
if u just want the sound that these short ram makes, i say go with any intake on ebay or whatever. 30 bux shipped to your door. because i dont believe intake make any difference in performance period.
Old 04-30-08, 04:04 AM
2jzism
2jzism's Avatar
Big
You can look into this from Weapon-r (yes guys I know) it doesn't seem to be a bad intake (Sport Compact Car did a shot-out back in 03 and out of something like 10 other manufacturers the Weapon-R showed the biggest gains across the board) so I can't be all that bad, its a pipe after all
Intakes do work, think of it this way when you run your month is wide open trying to gasp as much air as possible. Now go out and run but this time tape your nose shut and tape a straw to your month and see how your going to feel!!!
More noise is, but its not like if your just launched the Space Shuttle. It will get noisy under WOT other than that it won't drive you crazy
http://weapon-r.com/english/index.ph...oducts_id=5324
Old 04-30-08, 09:53 AM
swat1727
swat1727's Avatar
Originally Posted by 2jzism
Big
many people dont under stand. it's not how much air going through ur intake that will make a difference in performance. it's how much air can get into your engine... think about that uh?
Old 04-30-08, 12:11 PM
2jzism
2jzism's Avatar
That is correct, but when ever you can remove a bottle neck a performance gain will be seen.
Your engine will handle what ever amount of air can be pumped into it, if its boost, NA its just a big air pump.
How ever you go about it, More air+More Fuel= More power!
Old 04-30-08, 03:22 PM
Downfall75
Downfall75's Avatar
http://weapon-r.com/english/index.ph...oducts_id=5722
is this a good product?
Lexusjg1
12-09-17 08:36 PM
Sheehan1p
Performance
37
01-28-14 08:18 PM
GSRSRT
09-25-09 08:38 PM
haas
IS - 1st Gen (2001-2005)
12
01-19-03 11:35 PM
CIA360
Performance
04-27-02 10:56 PM
Quick Reply: Need intake advice
