unorthodox crank pulley
You're basically decreasing the rotational intertia of the crank pulley releasing a good 7-9 horsepower. By the way, the pulley weighs less than a pound and is built better than the factory pulley. Nothing else in the car changes.
If you're interested I have a brand new one for sale for the 2JZ-GE.
Originally posted by yoturk
does anyone have one installed,any real hp gains,any problems,any thoughts plzzzzzzzzzzzzzzzz
is there a way to get around that
when the crank is gone
just get a new higher performance one , that could take the vibrations
you would think a company would test their products to make sure they will wokr
why dont they just make it so theirs has a damener??
Here is what I found from their website.
7) "Will the underdrive pulleys cause my engine to have premature bearing wear ?"
This is a fear many prospective owners have and it is a valid concern since we are dealing directly with the rotating assembly. It is, however, a fear with no basis in fact. Today's modern small displacement 4 and 6 cylinder engines do not require harmonic dampers in the traditional sense.
Due to the design of our pulleys, both the smaller diameter and the significantly lighter weight, they are significantly better for longevity of the rotating assembly of your engine. The pulleys relieve unnecessary stresses inflicted upon your engine by the larger and significantly heavier stock unit, which has more harmful leverage upon the crank/eccentric shaft to which it is affixed
Ok take a look at this i post that info and these two guys like i knew they would have responded, because they both have seen first hand what these pulleys do to your motor.
I just want to warn anyone wanting these parts that will mess up their ride, if you still want them after reading this go right a head but you've been warned.
http://is300.net/forum/viewtopic.php...8159&forum=2&3
check it out respond there or here, however if you respond there likly SC300turbo and Is300GTE will respond to your questions or comments, this could be a good thing or a bad thing both these guys know there **** inside and out.
Hope this helps someone!!!
