Spark Plugs?
Old 05-01-08, 12:49 PM
CrazyIS
CrazyIS's Avatar
Default Spark Plugs?
I am not sure if this has been discussed before, but I was wondering if any of you tried gaining some power by changing plugs? There are so many Spark Plugs for many applications. Cold Irridium plugs for lean mixtures, hot burning plugs for rich mixtures.
Since we can't do much to our A/F mixture I am assuming we are running rich. so Denzo has some Hot burning plugs, and there is also Pulsestar.
What do you guys think.
Old 05-01-08, 12:53 PM
Pivo154
Pivo154's Avatar
I asked this same question everyone said we are running the best of the best. Same as the stock intake =0
Old 05-01-08, 01:03 PM
CrazyIS
CrazyIS's Avatar
Well then if no one has any real opinions I will have to try out some hot burning plugs for myself.
Old 05-01-08, 01:16 PM
Gernby
Gernby's Avatar
Hotter plugs won't increase power unless the stock plugs are fouling out. If anything, colder plugs could increase power if your car is currently retarding timing due to minor detonation from low octane fuel or hot climate. However, the last time I checked, there isn't a compatible plug in a colder heat range.
Old 05-01-08, 01:22 PM
Lextasy89
Lextasy89's Avatar
hmm for hot climate?? i could use some colder plugs in plano forsure
Old 05-01-08, 02:01 PM
CrazyIS
CrazyIS's Avatar
Autolite has Iridium plugs out.
I thought Denzo did but they don't for our cars.
Old 05-01-08, 02:33 PM
Gaugster
Gaugster's Avatar
I did some research on this a while back. A "hotter" plug is available but there is no advantage as this would probably decrease the engine performance.
http://my.is/forums/f155/2nd-gen-spa...ection-355643/
Regards,
Old 05-04-08, 03:01 PM
CrazyIS
CrazyIS's Avatar
I bought Pulsestar Spark Plugs Last week and I put them in this weekend.
I have only had them in for 2 days but I have driven 150 miles on them. So far they seem great. Right off the bat I noticed a difference in get up and go in low RPMS. Typically on my 250 I don't get the feeling of to much power until I get up past 4000 rpms. Now I feel the power is more even through out my acceleration.
My Butt Dyno is telling me that I have more power. Just a warning these plugs are expensive. Very expensive, but my personal experience is that I am getting better performance out of the PulseStar's compared to the Denso irridiums that come with our cars.
Old 05-04-08, 07:30 PM
Lextasy89
Lextasy89's Avatar
how much did you pay total? Did you put them in yourself?
also.. how long are our oem plugs supposed to last?
Old 05-04-08, 08:44 PM
Pnuge88
Pnuge88's Avatar
a bit off topic but how are your headers performing on your car? very noticeable gains? 25hp could def be ofhelp for these 250s
Old 05-04-08, 09:35 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,997 Likes on 2,421 Posts
No. Heat range has nothing to do with outside air temperature.
Old 05-04-08, 09:41 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I've never seen a sparkplug make more power on any engine unless there was a fundamental tuning issue with the engine. Resolving the tuning problem always fixes the problem at the source instead of masking it with a "special" sparkplug.
You might want to read this before making claims about "magic sparkplugs." Sorry, but you've been flim-flammed.
Old 05-04-08, 10:23 PM
Lextasy89
Lextasy89's Avatar
it does seem like people think they help somehow.. on dragtimes alot of racers have there spark plugs posted up like its a engine mod there trying to show off or something...
Old 05-05-08, 10:31 AM
Gernby
Gernby's Avatar
You don't think a colder plug could be beneficial for cars that run 20+ degrees hotter (coolant temp) because of extremely hot climate?
Old 05-05-08, 10:46 AM
RocketGuy3
RocketGuy3's Avatar
Would keying the plugs help at all in the IS?
Quick Reply: Spark Plugs?
