Finally got my PI TC installed. WOW!
#31
Didn't want to start another thread so I will just add my comments to this one. I just got my PI TC installed and i noticed the needle reaching the higher RPMs quicker but I don't notice that KICK that I was expecting. Its a very fast smooth shift but not that kick off the line... should i reset the car? Any help will be appreciated.
Am I expecting too much?
#33
I see that you have some 20's. I have 17" rims and I am sure that the bigger/heavier wheels make the results different. From a stop I have no problem getting the tires to peel out. Sometimes the car will even shift into second gear while peeling out. I don't know if that has to do with the smaller tires or if something else has to play into that.
I will be upgrading to some 19" rims soon so I will be able to put my input for that.
Try unplugging the battery and or double check to make sure that it was in fact a 2800 stall speed.
#34
anyone else can input your experience.
#36
...do you have black magic marker? or remove the bulbs...lol. You have a GS400...you shouldn't be getting any CEL. Check to make sure your tranny level is not too low or too high...believe it or not even a couple of ounces under or over will make our tranny's do very funny things. Also, make sure that you used Toyota type IV or AMSOIL ATF trans fluid (a little too late now though if you didn't). Then re-set your ECU...at least 30 minutes.
#37
#41
Here's a vid I took a couple of years ago when I had my 2800 stall PI installed. No LSD, just stock open diff.
http://www.fototime.com/DA3A4E2B82AA48C/orig.wmv
#42
There ya go. I was going to dig up this video. It's awesome
#43
#45
