Successful V160 Getrag swap into GS400/430... Anyone?
i would think to eliminate the CEL youd probably have to swap out your computers, TCU at least, maybe even ECU to maybe a supra one so that it is compatible to the 2jz and the getrag.
One question that has been flexing my brain big time !
if we do perform the swap.. and for once lets forget about all the physical aspects.. and focus on Electronics !
will the Factory ECU Start Goin CRazy once the swap is done ?!?!?!
because from my knowldge.. there is a Small Computer Unit only for the gearbox (E-shift stuff).. soo in other words... 1 is the ECU.. and 2 is the GCU (gear Control unit ) hehe my terminology bare with it !
soo wont the ECU start reading errors and flashing lights.. check engines.. and all that ?!?!?!!?!
I know it's getting old, but honestly that is the ultimate solution to everything lol. And if you're to the point of needing such a strong transmission such as the V160...you're probably making in excess of 700-800hp. It goes back to my original logic, you're probably running a standalone if you're at those power levels.
soo your telling me.. if i go ahead and replace my Auto Tranny of Stock ECU.. it will work with out malfunctioning ?!?!?!? except for the showing the lights.. but other than that.. our saying the ECU will function 100% the way it use to function when was stock Auto Tranny !?!??!
or will it give restrictions and Fail safe Mode... ?!?!?!?
Thnx your almost getting me excited hehehe !
supradean
Performance & Maintenance
09-19-07 10:52 PM
