K&N Drop in Air Filter
I just replaced all the air filters in my cars with K&N drop ins.
Gas mileage has improved between 10-20%![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Dealer mentioned they've had some check engine lights come on, has anyone experienced this?![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Also while searching the forum on the topic I cam across mention of the ECU being able to learn when the intake is changed. Is this a dealer option or user option?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thanks for any responses
Some will say that if you disconnect the battery, that you can reset it's settings to a new driving style. While that may provide an immediate effect, I also believe that the ECU is constantly adapting itself for your driving habits.
these previous replies regarding te mpg increase are most likely correct. i have never heard of a car getting even 10% increase in mpg from a filter let alone 10-20% increase.
you are either driving significantly more conservative, the warmer weather is helping, or your calculations are way off. if you reported hard evidence for even a 5% increase in mpg i would congratulate you
Had mine on for 5000 miles with no issues.
Like accelerate, I've had them on many vehicles with no issues (knock-wood). However, you will see people jump on here and say that it *could* potentially mess up the MAF, but that's only if you add too much oil to the filter.
I believe that what you are referring to is the ability for the ECU to "learn" and adapt it's settings based on your driving habits, air/fuel mixutre, etc, which is not really an "option" at all, but instead the way that the car operates.
Yes I've modified my driving habits, but I did that well before the filters were installed.
On the '02 ES300 - the best highway mpg I had ever seen was 28 (avg), more normally 26.5 (Avg). After the K&N was dropped in I hit 31.5mpg (avg).
My Kids '06 SantaFe popped from 18 to 22 highway after the filter was installed.
The SC430 I seem to be able to keep around 20mpg combined highway/local now, used to drop to 16.5 combined, it does more around town because of the wife.
The IS250awd is now doing 26mpg, from 24mpg, I think i can gooose it higher with driving technique. It's hard to hold the car back.
For the hell of it, I spoke with a contact I have Lexus corporate today and passed it along. Let their engineers verify or disprove it. If it holds true, I just saved them a whole bunch of R&D $$$$$.
The check engine lights was probably triggered from not sealing the box properly (made sure all the clips are fastened) or they over oiled the filter. A simple way to make sure the filter does not have too much oil is to dampen the filter with a paper towel after oiling it.
Koz
Koz
