** New ** PTS Full True Dual Exhaust – Joe Z series for IS250 & IS350
#244
AFAIK you're only looking about a 2 hp difference between versions... the main advantage of the street version is it might have a shot at fooling a visual inspector from noticing you're running an illegal exhaust system. (there's also a sound difference, but Joe Z himself has described it as slight, the race version being slightly louder)
#246
#249
Received 1,064 Likes
Yes it will work... There is an IS in this thread with a larger Rear lip kit..
The flanges can be loosened and adjusted by turning up or down to raise or lower the exhaust tips.
~ Joe Z
~ Joe Z
#253
Define emissions.
It's 100% illegal in all 50 states. That's why both versions have the disclaimer "For offroad use only" on em.
But it'll pass a "sniffer" test just fine. Engines are so clean these days you could probably remove the exhaust entirely and pass a sniffer test.
It should pass an OBD-2 test too as it doesn't mess with the O2 sensors or anything.
Anyone doing a visual check competently will outright fail the race version for missing cats.
Anyone doing a visual check who really knows what he's doing will fail the "street" version for removing the original cats.
Anyone doing a visual check and not paying much attention (which is most inspectors) will pass it.
#254
Why would an emissions place, in say Texas, fail you because you removed the OEM exhaust and replaced it with a catalyzed variant that passes safety, sniffer/OBD-2?
How is this "off-road use only" if it passes emissions?
#255
Because it's not the OEM system with the intended cat's.
Off Road Use Only is a way of protecting a manufacture's ***.
That being said, I would take a chance as the exhaust looks top quality! Yet I don't have testing here in Kentucky!
