** New ** PTS Full True Dual Exhaust – Joe Z series for IS250 & IS350
It says California certified cats. What does that mean exactly they're CARB exempt? I thought it was illegal to change out the cat's in CA no matter what? I might consider this exhaust if it's quiet.
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Ok gang... here are the DYNO's which were performed on a Bone Stock 2006 IS350.
During this part of the R&D process, I did not have my 08' IS350 yet..
We had a Base run with a 265 rhwp pull, but some how the data file was lost.
So we had to use the base run for the graph which shows the 262rwhp base run pull..
The Dyno was completed on a stock IS350 which only had the exhaust upgraded for the DYNO's.
Also, testing was done in normal mode and only up tp 4th gear...
Below is the dyno graph of the Base run verses the "Street Performance" version w/ CATS.
- Gains will be approx 8 peak rwhp on this system.
![](https://www.clublexus.com/gallery/data/4400/thumbs/IS350_Dyno_Sheet_1A.jpg)
Below is the dyno graph of the "Street Performance" version w/ CATS verses the "Race Performance" version w/ OUT CATS
- Gains will be approx 10 peak rwhp on this system.
![](https://www.clublexus.com/gallery/data/4400/thumbs/IS350_Dyno_Sheet_1B.jpg)
Thank You
Joe Z
Thank You
Joe Z
Both versions are Full Aftermarket exhaust replacement parts and carry the disclaimer:
“For Off Road Use Only”
The "Street Performance" version includes two high flow Carb Certified CATS.
Does that make more sense now??![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Joe Z
Joe Z
It would be really interesting to see these results stacked up against the results of another popular exhaust such as the tanabe.
How much does the exhaust weigh? is it lighter than the stock setup? if so by how much?
and is there any interior drone or resonation?
On the "Race Performance" version there is no high speed droning or resonating sounds. The overall sound does slightly increase on this version, due to the lack of CATS. However, it is still a Sport Luxury Sound.
OEM Exhaust Weight
Front-Mid Section = 28lbs
Rear Axle Section = 40lbs
Total = 68
Street Performance Weight
Front Section w/CATS = 16 lbs
Mid Section w/Resonators = 20lbs
Dual Rear Sections w/Mufflers & Tips = 32 lbs
Total = 68
Race Performance Weight
Front Section NO CATS = 13 lbs
Total = 65
Original CL Sponsor since 1999
The exhaust looks like its sitting in the right place to me. The tips cant be too close to the bumber b/c the rubber hangers allow for some play and no one wants to hear their tips rattling against the bumper...not to mention that heat can sometimes become an issue too.
Nice work JoeZ!!! I am offiacally on TeamEnvy...that is until i purchase mine![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
When is the GB gonna go down?
