SRT Intake on gs 300??
#31
Make sure your mass airflow sensor is pointing in the correct direction.
If that's not the issue then it may be just from the intake causing a lean condition since you are adding more air but not compensating for it (hence the reason the Srt setup comes with a piggyback ecu).
#35
S.A.F.C.=super air flow converter
They are made by Apexi--> http://www.alamomotorsports.com/apexi/safc.html
You splice it into your stock ecu wiring harness and strap your car on the dyno. Your tuner will be able to make changes to correct your air/fuel ratio so you don't run too rich or too lean, in your case. This is the same as the SRT ecu, except that the safc's settings can be changed to accomodate any intake and other supporting mods, as opposed to the SRT ecu which will only work the SRT intake.
