HKS... turbo? (New Supercharger Shown!)
#61
Wouldnt it be possible to have a piggy back system to run the super charger because i think to have any of these supercharger systems that includes Toms and LMS you had to do some kind of modding to the ECU and a piggy back system would achieve that wouldnt it?
<-- noob when it comes to turbos s/c or anything with the engine. So this just an amature idea
#63
As to a piggyback, none exist for this car that can do anything other than A/F tuning. You'd need to adjust timing and whatnot for forced induction.
But even if you COULD do that... the TOMs kit in Japan which DOES modify the ecu only increases boost from the 5 lbs of the LMS kit to the 5.8 lbs of the TOMs kit.
Wow... a whole 0.8 pounds more boost.
Do whatever you want to the ECU, you're not gonna run a ton of boost on a 12:1 compression engine, especially not with the stock internals.
#64
2IS OG
I've just deleted over 30 posts from this thread. Let's try and stay on topic here gang. This isn't the 'supercharger vs. turbo' thread, nor is a debate about the cost effectiveness or merits of boosting your car. Keep the posts about the HKS supercharger or start a new thread.
Javier
Javier
#71
The part where they explain that isn't what it is at all?
It's just a service where they reflash your stock ECU. And ONLY a JDM ECU. And it's mainly so you can see some benefit to running 100 octane with their supercharger kit. Even then it's a small benefit (you can run 5.8 lbs instead of 5 like LMS kit does on the stock ECU with 91 octane)
And again, for JDM cars only.
