Makeover time!! GS400TT upgrade/build has begun (pic happy)
Old 01-19-09, 11:10 AM
  #151
Hudini
Hudini's Avatar
Ssst Hui manong....
I will be out your way next month Feb. 21st for a week. I think I might need a REALLY FAST ride home from the airport. Looking and sounding really good Ricky!!
Old 01-19-09, 11:55 AM
  #152
HI98GS
HI98GS's Avatar
Originally Posted by Hudini
Ssst Hui manong....
I will be happy to give you a ride, just let me know what time. If I am free, I'll pick you up. I am planning on dyno the second week of Feb. Got a new ECU being placed. Also gonna try using a dynopack setup to help with street tuning.
cell's still the same.
Aloha
Old 01-21-09, 12:17 AM
  #153
Kaluna
Kaluna's Avatar
Impressive... man I wanna see that thing one of these days. Mean...
Old 01-24-09, 12:02 AM
  #154
HI98GS
HI98GS's Avatar
So here are some pics of the motor in it's new home.
I cleaned up the wire loom. Still need to do some real tuning, but gotta break it in first.
Old 01-24-09, 07:16 AM
  #155
gs300pnp
Registered User
gs300pnp's Avatar
Default It's awesome to see more and more "LEXUS" performance builds like this.
I'm impressed with the quality of the motor build and tasteful finishes.
This is inspiring and makes me want to pick up a 2nd Gen and build the motor similar to this. I'm looking forward to learn more about the modded toyo tranny and how it performs.
Great Job!
Old 01-26-09, 08:30 AM
  #156
sakataj
sakataj's Avatar
we want more....more.............
Old 02-06-09, 04:57 PM
  #157
503-M3
503-M3's Avatar
4 digits!!!
all on your nut sack!
Old 02-06-09, 05:38 PM
  #158
HI98GS
HI98GS's Avatar
Originally Posted by 503-M3
4 digits!!!
3 digits are fine as far as the first one starts with 6! This is my daily driver!!Not all of us are lucky enough to have 2 vehicles to drive.
Lend me one of yours.
Old 02-09-09, 01:43 PM
  #159
sakataj
sakataj's Avatar
when u finishing the tune? u broken her in yet?
Old 02-10-09, 08:35 AM
  #160
503-M3
503-M3's Avatar
You can drive Maroon 5 just don't get the garmin jacked out of it again
Old 02-17-09, 07:43 PM
  #161
HI98GS
HI98GS's Avatar
So small update on the car.
The current ECU (Autronic SM4) has been replaced. The only reason is due to the fact that the current software cannot recognize the toyota cam sensor pattern. For those of you with VVt-i (on the 1uz) there are 3 cam triggers that are eccentrically spaced (not 120 degrees between triggers) There doesn't seem to be a fix for this, the software has not been designed. Sooooo instead of waiting for the software, I decided to go with another unit (name withheld for now) This unit I was guaranteed to control everything including the vvt-i.
I was initially thinking of only going with the stock fuel setup. But decided, since I jumped off the cliff, I am already way into it, just make sure the mountainside is very high.
So here's some new stuff to be installed, after the new ECU is fully functional. The ECU is already in and the car is alive. Just need to get it tuned up some, then off to the dyno!!
I also have a dual pump hangar that will be installed with 2 walbro 255Lph pumps. The setup will run individual -6 lines to each fuel rail. Then return via an SX fpr.
Talk about going off the deep end
Did I forget anything? let me know!
Old 02-17-09, 07:50 PM
  #162
Gytis123
Gytis123's Avatar
Wow nice build for sure!
Old 02-18-09, 12:10 PM
  #163
sakataj
sakataj's Avatar
i know u trying to keep it a secret (although im not sure why) r you running a motec now? would be a odd ecu for the gs but besides a haltech not sure of what else you might be running. as always your my hero man
Old 02-18-09, 06:58 PM
  #164
CinFulxgs
CinFulxgs's Avatar
Old 02-19-09, 08:27 AM
  #165
HI98GS
HI98GS's Avatar
Not running a motec or HKS or Haltech. I just want to keep the ECU under wraps until I am sure it runs the VVt-i as it claims. I don't wanna provide info that isn't real. I guess I am the guinea pig on this since I know that no-one has used this system yet. I will let you all know when it is controlling the motor as I need it to do.
If you wanna know just pm me.
Quick Reply: Makeover time!! GS400TT upgrade/build has begun (pic happy)
